rough idle stalling after engine swap
  • geldartb
    The Situation
    • May 2004
    • 1994
    ok swapped out the motor in my grand am with a 05 3400 with 300 miles on it.
    got everything back together and now it will idle around 2grand and then gradually die off completely stalling the car out. this is a brand new motor practically, it should run fine.
    already checked th iac and swapped out throttlebodies cause the plenum and tb were diff than what i had. but everything else is brand new.
    99 Grand Am GT
    1357 cam 227 233 .050 dur
    515 515 lift 112 lsa
    Sounds like a vacuum leak maybe?
    • geldartb
      The Situation
      • May 2004
      • 1994
      yeah it was plenum had a crack in it. swapped it out and everything is fine.
      99 Grand Am GT
      • ryan.hess
        • 526
        Plenum had a crack?
        Got a pic?
        Okay now, that's enough of that.
        • geldartb
          The Situation
          • May 2004
          • 1994
          ill get one later it was right above the bolt hole through and through. on the alt side.
          99 Grand Am GT
