Internal and External
  • Ray Hamilton
    • Feb 2007
    • 239
    How can you visually tell what a stick flywheel is? The flexplates have a chuck of metal welded to them if external. How about the standard?
    '86 S10 Blazer 4WD, '87 2.8 with 3.1 crank and pistons, A.R.I. "Stage 2 Cam", Iron Heads with stiffer springs, Holley TBI, Manifold bored to fit the TBI Base(4.3 size), Fiero Covers, MSD Coil, DynoMax Muffler and 2.5 Tailpipe, no cat, Auburn Limited Slip, 3.73 final Drive. 700R. '85 Fiero GT 3.4 Hybrid, relieved top intake and exhaust, 57mm TB, Auto. 3.06 final drive.
  • geoffinbc
    Iron Head Enthusiast
    • 5831
    An internal balance wheel will have a clean back on it. The external balance wheel will have a cast in lump on the back.
    Internal balance http://members.shaw.ca/betterthanyou...e_Flywheel.jpg
    External Balance
    • Ray Hamilton
      • Feb 2007
      • 239
      Just saw it and found the chunk. This engine came from an '88 but apparently it was externally balanced. Then again, it wasn't the original engine, it was a rebuild. I have a flexplate that I've removed the balance on it, will the front balancer work or does it need to be changed too? This is my thread as to what I'm attempting. http://60degreev6.com/showthread.php?t=35749. My block is ready to go and I have purchased all new parts. I was surprised to see it was externally balanced. I was reading some 2.8 history last nite and it said it was a hit and miss thing whether they balanced them one way or the other. No way to be sure w/o looking.
      Thanks for the reply.
      • RacerX11
        • 1060
        Harmonic balancers are all neutral balance, so you should be fine.
        '99 Z-28 - Weekend Driver
        '84 X-11 - Time and Money Pit
        Quote of the week:
        Originally posted by Aaron
        • Ray Hamilton
          • Feb 2007
          • 239
          Great, thanks for the reply!
          • Ray Hamilton
            • Feb 2007
            • 239
            I was wondering about these balancers again. I have a couple that have a small tab cast into them and then some w/o the tab. It's small but it's there. Doesn't mean anything?
            • geoffinbc
              • 5831
              pic? Are you sure it is from a 60* v6 Some other engines did have an off balance damper along with the flywheel.
              • Ray Hamilton
                • Feb 2007
                • 239
                Check here "with weight".http://www.damperdoctor.com/Merchant...&Store_Code=DD
                Schucks has the same Dorman part number from "84 to '89, but different numbers for the "Pioneer". I posted a pix with the tab casting(left top) and w/o, both from a external balance engine. After more looking and comparing, the "Autozone" "Pioneer" balancer for an '89 is .56 lb lighter than an '86. I'm thinking there is a difference between the externally balanced and internally balanced if ever so slight. But Dorman lists the SAME part number for ALL balancers for S10 2.8's from '84 to '89 and even '90 Camaro's which have the 3 spoke pulley. I believe there are Neutral pulleys, such as the Dorman's, and some that are balanced, Pioneer's.
