how to check Codes
  • MATT2007
    • 127
    how to check Codes
    I have a 91 beretta and It is running bad I know ther is a way to check with a paper clip how do I do this
  • Carlspike
    • Oct 2005
    • 154
    bend a paper clip in a U shape. Slide 1 end in each of the two terminals on the bottom row all the way to the right. Then turn the key on and watch the service engine soon light flash. I.E. 1 flash then a pause then 2 more flashes means code 12. Each code will flash 3 times. The first will be code 12 (that just means the computer is communicating) and any trouble codes will follow code 12. Then it will end again with code 12.
    • SY2932
      • Feb 2005
      • 5
      If you haven't deciphered the code(s) yet, you can figure out what they mean here.
      Mike Campbell
      1988 3.4 V6 S10
      1991 4.3 V6 SYCLONE 12.4 @ 107 0-60
      http://www.sytyarchives.com/database...ser.php?id=147
      http://www.centergc.org/images/misc/...one2932?page=1
      • TazMan
        • Jun 2006
        • 285
        On my 92 GP it's pins A and B and they are on the top row, not the bottom, all the way to the right. I think it would be the same for your car but I would double check before doing it.
        • neo71665
          its this big
          • Oct 2005
          • 361
          The pins are on the top right in my blazer.
          87 3.4 4x4 blazer
          • onefastV6
            • Sep 2005
            • 880
            Don't they make a code reader for OBD1?
            2000 Grand Am GT
            2011 Chevy Impala
              • 9191
              Yes, they do.
              Edit - Post #100,000
