Does such a part even exist for the engine in my sig? Already have an A/C delete pulley for a V8, and am just about ready to modify it some to adapt to the 3.1, but before I go through the trouble, has anyone heard of an afermarket source who literally makes them....?
Smog Pump Delete Pulley....?
Tags: None
You should be able to just take the smog pump out and run a shorter belt. You would go from the alt. to the crank and then the water pump.
My CarDomain Site--------The Camaro Song
Considered that, but it would be much easier for me to simply modify the A/C delete pulley. The A/C on the 3.1 has already been tossed, and it would probably take me longer to find a matching belt (minus A/C and smog), then it would to convert the piece. Either way, will have pictures for this thread when done....Originally posted by grimmcs View PostYou should be able to just take the smog pump out and run a shorter belt. You would go from the alt. to the crank and then the water pump....
I agree with the other guys, just delete it all together. Finding the right belt is just a matter of running some rope around the pulleys and marking/measuring it.
It's a little bit more complicated than that, as I'm simply not looking to run a shorter belt. I honestly need to re-use the factory belt to run my Vortech S/C. I already fabbed the delete pulley using the V8 one, I just didn't want to ruin it, and was hoping that an aftermarket source offered them before I altered it....Originally posted by ForcedFirebirdI agree with the other guys, just delete it all together. Finding the right belt is just a matter of running some rope around the pulleys and marking/measuring it....
Oh well you didnt mention the S/C... The only smog delete pully Ive heard of is from GM---> LINKOriginally posted by Street Lethal View PostIt's a little bit more complicated than that, as I'm simply not looking to run a shorter belt. I honestly need to re-use the factory belt to run my Vortech S/C. I already fabbed the delete pulley using the V8 one, I just didn't want to ruin it, and was hoping that an aftermarket source offered them before I altered it....
Thanks for the link. Yeah, I've been a member over on ThirdGen.org for four years now. Already modified my existing delete pulley, and it came out rather well. Didn't mention the S/C, initially, as I was hoping I didn't have to. Was looking to surprise a few certain people....Originally posted by grimmcsOh well you didnt mention the S/C... The only smog delete pully Ive heard of is from GM.
I'm still not getting it I guess. Even with the S/C in place, you can still measure for a different belt as long as the pulleys are turning in the right direction.Originally posted by Street Lethal View PostThanks for the link. Yeah, I've been a member over on ThirdGen.org for four years now. Already modified my existing delete pulley, and it came out rather well. Didn't mention the S/C, initially, as I was hoping I didn't have to. Was looking to surprise a few certain people....
Well, now you let the cat out of the bag....
now you are going to have to share
Is this "First-Firebird"...?Originally posted by ForcedFirebirdI'm still not getting it I guess. Even with the S/C in place, you can still measure for a different belt as long as the pulleys are turning in the right direction.
Well, now you let the cat out of the bag, now you are going to have to share...
You'll see pics very soon...
Just wanted to elaborate for you guys, as after re-reading my first post, I see how confusing it might have been to picture everything;
Stock 3.1. A/C was tossed, and was running a non A/C serpentine belt for quite awhile. Decided to lose the Smog Pump, but wanted to use a pulley, as opposed to running a shorter belt. The V8 delete pulley that I modifed is where the Smog Pump used to be, not the A/C...
Why yes it is! =) Haven't changed mt name at TGO yet, lol.Originally posted by Street Lethal View PostIs this "First-Firebird"...?
I still don't see why you couldn't use a shorter belt, it woul actually help keep fron slipping with the S/C.
I agree with the slippage issue, but I need to get this thing tuned right away. A shorter belt is definitely an option in the near future though, that's for sure....Originally posted by ForcedFirebirdI still don't see why you couldn't use a shorter belt, it woul actually help keep fron slipping with the S/C.
Well you can still surprise most of the people over in TGO. I havent seen too many people from there over here.Originally posted by Street Lethal View PostDidn't mention the S/C, initially, as I was hoping I didn't have to. Was looking to surprise a few certain people....
So how far along are you?My CarDomain Site--------The Camaro Song
True, but you never know....Originally posted by grimmcsWell you can still surprise most of the people over in TGO. I havent seen too many people from there over here....
Still finishing up the bracket to support the Vortech unit. Waiting patiently to do so, as I need to start burning a PROM soon. Mega-Squirt is a given, but that's later on though...Originally posted by grimmcs View PostSo how far along are you?
