LIM or head gasket or ?
  • roxtro
    • Apr 2007
    • 7
    Need alittle help from you guys, THANKS in advance. My son just started driving our 2000 pushrod 3.1 alum head malibu that has about 70k miles on it and i screwed up, i put off showing him the gages and everything for a couple weeks because what could happen in a couple weeks? Shame on me. It had a blown head gasket 3 years ago under extended warrenty when my dad owned it.
    He said a red light came on in the dash and the temp needle was all the way up in the gage, he was about 30 seconds from home so he drove home and shut it off. I took it down to the local garage,they tried to do a pressure test but they said LIM gasket was so blown it would hold no pressure at all. The dip stick showed allot of water in the pan.They said $700 at least....sorry Ill try it myself, Im a machinist and I built a 327 30 years ago.
    We put a new fel pro LIM on and just filled it with water for 1st start up(shop had put green in it 3 years ago,not sure if they got all dexcool out).
    Had new thermostat but forgot to install it. It has no rad. cap so I let it idle and kept filling overflow tank, it got to the correct temp and stayed there so we took it for a drive w a jug of water. About a mile down the road the needle started climbing so i shut it off well before red and filled overflow, thought it just wasnt full....but the next day it did the same thing and it was low on water again, strange thing though even though the needle never went into the red area that engine seemed damn hot, the upper rad. hose was pulsating like a human heart and steam came out of the overflow bottle. There is a light vapor and water in the tail pipe on startup but after a 3 mile drive today i checked it and there was no vaper but just a small trace of water. Overflow was low on water again. There is a loud clicking noise in the engine bay when i rev it up...possibly from alternater,waterpump or rocker arm?
    I pulled all 6 plugs out at the same time tonight and the compression checked 180-140 lbs. with no plugs in it.(cranked 5 seconds per cylinder). There is NO water in the oil. I hooked up 1 of those prestone flush kits to the heater hose and water poured out of the upper rad. hose that i took loose.
    So is the problem
    1) blown head gasket
    2) straight water, no antifreeze yet in engine
    3)water pump
    4)air pocket in coolant system
    5)blockage in coolant system
    6)thermostat
    THANKS.
  • PCGUY112887
    • Feb 2006
    • 1067
    I think you may not have all of the air out yet. If you had a blown head gasket or a warped head leaking you would have a coolant mess everywhere and you wouldn't keep compression. Tstat could also be faulty, not opening letting the engine get real hot and tons of pressure building.
    Edit - Wouldn't a compression test still show pressure even if your LIM gasket was bad? Did it look bad when it came out?
    SpudFiles
    Theopia
    Enjoy life online.
    • roxtro
      • Apr 2007
      • 7
      lim
      I remember when we 1st started it up after changing LIM i saw bubbles churning in overflow bottle while i was filling (no rad. cap) but havent seen that since.they could have been normal air in system or blown head gasket?
      Before I changed the LIM I could see it breathing at the low point where it mates w the block on drivers side.
      Im not sure if i could get 180-140lbs compression w blown head gasket or not.
      • pontiac3100
        • 226
        nope infact if you had a blown h/g the engine whould act as if it had a horrible missfire.
        plus from what i'm told...and seem to agree with is the only time the h/g blows on these engines is when the owner lets it over heat x amount of times.
        that shop i think was trying to get over on him...reason being this is a common problem,till you buy the felpro hi-end gasket set.
        1992 nissan maxima se (190hp/205tQ)
        • 95Grand-Am
          • 268
          Did you find the air bleeds on the cooling system? I believe there are two, open them up until coolant comes out. Also run the heater, at first because this will help get the air out of the heater core and lines. If the engine is warm and no heat is coming out, then open you air bleeds again. It may take a few times to get all the air out. Some of the engines are a real pain to bleed out.
          • roxtro
            • Apr 2007
            • 7
            does anyone know where the air bleeds are, there is no rad cap(overflow bottle)
            ps-whats the deal with that white plastic drain plug at the drivers side bottom of radiator, that thing is a piece.
            • PCGUY112887
              • Feb 2006
              • 1067
              There should be one on/near the upper rad line, then another one towards the left of the engine on the hard coolant line. May also be one on the left near the waterpump.
              Just look for knobs on/near the cooling system that you can stick a flat head screwdriver in.
              SpudFiles
              Theopia
              Enjoy life online.
              • roxtro
                • Apr 2007
                • 7
                RE:MISFIRE
                pontiac3100, re. misfire-engine runs really runs good and smooth.
