Rough, lopey idle
  • Azrael
    Accelerating uphill in OD
    • Apr 2005
    • 763
    Rough, lopey idle
    My small-port 3100 developed a rough idle and sounds like it's aggressively cammed (oh how I wish it were true). Only happens when the engine is idling, in gear or not. My vac/boost gauge is reading a few inches of vacuum less than usual but the RPM is a little lower than normal and sometimes borders on stalling. During acceleration or cruising the engine runs fine but there is a noticeable drop in low-end power.
    Any ideas? I thought vacuum leak at first but that usually results in a high idle. Thanks in advance.
    1995 Grand Am SE
  • sil
    4T60-E killa
    • Nov 2004
    • 723
    have ya looked at your spark?
    maybe coil/wire/plug is bad
    • Azrael
      • Apr 2005
      • 763
      The front, three plugs look fine and all the wires make a good connection. There's no hesitation while accellerating so there isn't any misfire that I can see. I'm going to check the IAC valve tomorrow and change the fuel filter if I have time. I did fill my gastank a few days ago too. So it could be just a bad bit of gas.
      1995 Grand Am SE
        could be a leaky injector.. my old 3.1 did that all the time..
          Would the 24x sensor cause it to run that bad? I know the 24x is used for idle and low RPM smoothness...
          • Azrael
            • Apr 2005
            • 763
            Thanks guys. It turned out to be an easy fix. The minumum throttle set screw on the throttlebody (an old billet FDP unit) came lose and bottomed out, letting the butterfly plate close too much. The IAC must have went crazy trying to compensate. Added some loctite and set it back to where it was. A little bit of driving later and the idle and vacuum returned to normal.
            1995 Grand Am SE
              cool!
