3.1 head replacement
  • garylau
    • Aug 2007
    • 57
    I'm going to be replacing the heads and intake gaskets on my '97 Lumina 3100. From what I can see this is going to be different from the heads I've replaced on two other vehicles. Does anyone have a link or anything that will run me through it so I can see what I'm up against?
  • JoeMechanic
    • Aug 2007
    • 78
    AllData online at your local library...it has everything you might need to do.Its usually in the librarys research data base and its FREE and you can print out anything you need..its awesome!.
    • garylau
      • Aug 2007
      • 57
      I'm not sure that my crappy little library has that but I'll look into it. Thanks. I did a search here but didn't quite find what I was hoping for.
        • 9191
        If its not at your library, you can spend $20 and get a year subscription for 1 car, and $15/yr (or $25 for 3 yrs) for anything after the initial car. I've been an AllData member for geez... 5 years now? I've gotten a ton of info off of it, and its been well worth the money IMO.
        • garylau
          • Aug 2007
          • 57
          Sounds cool. I'll have to look into that.
