"In block" oil pressure valve
  • 85_Olds_Ciera
    • Aug 2007
    • 259
    PF52 is the biggest you can go depending on which adapter then engine contains.
    RE: 88 Beretta Oil Filter: 2.8
    I got the biggest...and it rubs on engine cradle assembly when accelerating...but a Fram: PH3682 might do the trick...I'm road testing it now.
    If this vendor has the sizes correct below, PF52 will rub out on cradle's undercarriage.
    AC PF52
    FRAM PH3980
    PUROLATOR PER4457
    WIX 51036
    In other words, all of these filters above should not be used...unless you want to cut away the cradle's frame a pinch.
    • 1988GTU
      LB62LHObbqftmfw
      • Nov 2005
      • 2475
      Then take off the adapter.
      • 85_Olds_Ciera
        • Aug 2007
        • 259
        Bring me upto speed here....then what when adapter is off?
        Are there kits to setup lines for feeding a larger filter?
          • 9190
          The filter can either be mounted directly to the block and sit at an angle, or it can be mounted to a factory adapter and sit vertical.
          • 85_Olds_Ciera
            • Aug 2007
            • 259
            Thanks....I'll have to take a closer look...there is a diagonal "cross member" on this cradle setup, which is causing the problem in the vertical direction, but I think this cross member may also be in the way in the 45 degree direction.
            With the longer filter, the filter is hanging below the cross member, which means any road hits would take the filter out...I live on country roads...and stuff happens with rocks and bumps...
            thanks...I'll have to look closely.
            • 1988GTU
              LB62LHObbqftmfw
              • Nov 2005
              • 2475
              #21
              I know what teh 88 Beretta is all about. With no adapter it works fine. I think even when it had the shorter style adapter it worked just fine then too. There should not be that much engine movement, if there is then you may want to check into that concern.
              • 85_Olds_Ciera
                • Aug 2007
                • 259
                #22
                I had full brakes on while slipping the pedal some fuel in forward/reverse gears, and had someone watch motor...there was about a quarter inch play at outer end of oil filter to cross member, but it kissed the cross member...that's not much actual engine movement, when you consider the oil filter is at outer end of motor's rotational movement....and I think this motor/tranny is top mounted, but I'll have to check to see where motor mounts are...either way, not much movement for RPM used to test it.
                but thanks for suggestion.
                • 85_Olds_Ciera
                  • Aug 2007
                  • 259
                  #23
                  ...88 Beretta is all about. With no adapter it works fine...
                  AC lines may cause some irritation...but for sure, take them away, and it will work for sure.
                  Btw, where did you get an "adapter bolt" that mates Oil Filter to block facing?
                  • 85_Olds_Ciera
                    • Aug 2007
                    • 259
                    #24
                    Note - Either way it is mounted, GM came out with an adapter...so an adapter apparently is needed.
                    • 85_Olds_Ciera
                      • Aug 2007
                      • 259
                      #25
                      I went and bought an AC PF52 oil filter...and it is a pinch shorter than Fram's 3980...it appears, so far, it may work...so far, this filter has not hit the engine's cradle framework on this 88 Beretta.
                      Just have to monitor it
