I am having a problem find replacement mechanical fuel pump for 2.8 Z High Output in my 1983 Pontiac 6000 STE. As some may know this H.O. version of the 2.8 first appeared in the Chevy Citation (with a change to the fuel pump rod in 82). Both Delco and Airtex list the pump as # 42138 ( alternate 6442318 ) for the standard X code of the is engine but not the Z. Retail parts sources list the pump for both X and Z. Anyone know if this is the same pump, if it will work or if there is another source for the exact spec pump.
Replacement Fuel Pump for 2.8 Z Code High Output
