Hammered Crankshaft
  • 85_Olds_Ciera
    • Aug 2007
    • 259
    Hammered Crankshaft
    I may have a chance to pickup cheap a 1989 Oldsmobile Cutlass Calais with Quad-Four, that has some hammer time on one rod, most likely.
    Is it possible to have submersible welding done on rod journal, if this is the case?
  • geoffinbc
    Iron Head Enthusiast
    • 5831
    Do you really think a quad 4 crank is worth the investment? If you want the motor and it is cheep go for it. But ditch the crank if it is damaged. There is no way it can be repaired cheaper than what you could pick up a good used one for.
    As for repairs it does not need any fancy welding done to it. It simply needs the right filler metal added and the correct heat treatment process either before, after or both. But the hours invested would in no way be cheaper than a good used crank.
    • 85_Olds_Ciera
      • Aug 2007
      • 259
      Yes/No...I can use the tranny out of it...or sink an Iron Duke in it, if I could find the motor mounts for it.
      Vehicle is clean...and last time I had a crank turned and welded on for thrust bearing surface, it was only $125.00 with bearings included, and shipped to my door.
      Where do you find cheap Quad Four cranks?
      • 85_Olds_Ciera
        • Aug 2007
        • 259
        Footnote = "Our extensive research shows there are actually a total of six different blocks, three cranks, three rods, seven heads, four cam housings, four front covers and three oil pumps used on these engines from 1987 through 1995, and that doesn’t include the changes that were made for the 2.4L engine! It’s no wonder that everyone seems confused about what goes where, when and why.
          • 9190
          Why do you keep posting about 4-cyl engines?
