blasted O2 sensor
  • Kardain
    • Nov 2006
    • 111
    blasted O2 sensor
    So... I'm getting the HO21 no signal CEL
    I've run 2 new wires straight from the ECM to the front O2 harness side plug bypassing whatever was in the harness and , ran a new ground and still getting the CEL (and no reading while engine running on my scan tool).
    Also bit the bullet and purchased a new O2 sensor...
    Still nothing.
    Any ideas?
  • Kardain
    • Nov 2006
    • 111
    So, the 99 PCM that I had went *poof*... not sure what happened.
    Got a 2k1 PCM from eBay (that seriously smoothed the idle out alot), but still have the P0134 code... and get to reset it for a 5 spd
    I know there is 1 extra wire in the 2k1 harness that basically loop from 1 pin to another on the PCM for the front O2, so I have to repin that, but this is a carry over from the previous PCM that was in there.
    I find it odd that I can't get a signal of any sorts coming from either PCM...
    So I'm running a 99 harness, with a 2k1 PCM on a 2k1 3400
    Anyone have a clue (or do I even need that loop back)
    • IanSzgatti
      • Oct 2006
      • 519
      At the moment I have nothing to say relating to your problem... but I had to post here and say that I hate newer cavaliers, sunfires, etc... You however, did what had to be done and shoe-horned a 3.4 into a sunfire, which probably makes them a car rather than a go cart.... nice job. If I come across anything I'll let you know
        isn't that ECM looking for 2 o2 signals? one at the rear manifolds and one after the cat... ?
        • Kardain
          • Nov 2006
          • 111
          ^^For now, yes, till I get around to deleting that code out for the rear O2. but they are seperate circuits.
          IanSzgatti: I wanted a car that I could have fun with that wouldn't cost an arm/half-a-leg
            Maybe something is shorted out and thats why the 99 pcm took a crap after a while....
