Oil pump prime CW or CCW ?
  • Mars
    • Apr 2004
    • 826
    Hello everyone,
    Which way to you need to spin the oil pump drive to get some priming action?
    Thanks!!
    Is this even required when starting a new engine after a cam install (I used oil on the lobes, and assy lube on the bearings)
  • geoffinbc
    Iron Head Enthusiast
    • 5831
    Clockwise.
    Yes you should do it on any new build or rebuild.
    • geldartb
      The Situation
      • May 2004
      • 1994
      just dont do it too fast or youll get oil spitting out the hole where you put the oil pump drive in to prime it
      99 Grand Am GT
      1357 cam 227 233 .050 dur
      515 515 lift 112 lsa
      • Mars
        • Apr 2004
        • 826
        I tried w/ my 3/8" air ratchet and it's not fast enough....
        I don't have anything that fits in my elec. drill chuck....
        Find something at the hdw. store later on.
        • geoffinbc
          • 5831
          Chuck up an extension with an 8mm socket. Tape the socket on in case it falls off.
          • Mars
            • Apr 2004
            • 826
            Good idea with the tape.
            Thanks.
            I am glad I posted cause I was about 95% sure you had to spin that thing CCW.
            • silvergtjrad
              uber slow grand am
              • Feb 2007
              • 302
              Cant you just turn the engine over with the starter to prime it?
              • geldartb
                The Situation
                • May 2004
                • 1994
                yeah but your still dry running it till the oil flows.
                with doing it this way you get oil up in the lifters and everywhere its suppose to be, before you even rotate anything in the engine so when you do actually start the engine in the car oil is where it suppose to be.
                i dont know about you but after i spend the time to build it and what not, id go with the drill route.
                99 Grand Am GT
