Hey i have 01 3100 topend, can someone tell me the stud is 47 lbs? and the roller rocker is 18 lb? It is turbo so i want to make sure.... any help apreciated, btw i dont have a 3100 manual...
rocker arm and stud Torque specs
Tags: None
dont remember when they changed the stud size but this is from my 99
Rocker arm bolt 14 N.m (124 lb. in.) plus 30°sigpic
99 Grand Am GT
1357 cam 227 233 .050 dur 515 515 lift 112 lsa
sounds right^^^94 BerrettaZ26 3400,5 spd, aluminum flywheel, stg3+ spec clutch, poly mounts everywhere, strut and strut to rad braces, s&s headers, euro mirrors, and taillights, E36 headlights, blk widow spoiler, GTU rimz, intrax, KYB, OBD2 swap rear disk swap with ss lines and ss clutch line, addco rear bar
i got that from my alldata online so it better be right.sigpic
99 Grand Am GT
I torqued my 97 lumina's to 25 ft/lbs. then drove it for another two years w/o problems--even after I found out that at 35 ft/lbs the threads in the heads are at the max!. yep! heli-coiled it!
i didn't have a way to measure degrees haha oh well!
Andy
fastest 1/8: 10.19@ 67.17
fastest 1/4: 16.16@ 82.70
1 flat = 60 degrees.
Note that Geldartb said 124 INCH-pounds plus 30 degrees. Not Foot-pounds. There's always some rocket-scientist who confuses these two... resulting in broken parts.
damn that reminds me i need an inch pounds torque wrench and a torque wrench that goes higher than 75 ft lbs. at the time that was higher than anything i was doing.sigpic
99 Grand Am GT
i you can't torque the rockers to 124 ft/lbs. the threads will strip out waaayy before that. damn aluminum.Andy
Hrmmm I always just made them tight... without a torque wrench... never had a problem with mine.
Impact gun FTW!
I forget what I put mine at but it's what chiltons said and it's just torq and this it, no extra turning. Done it 3 times and no problems.sigpic
