High/Fast Idle
  • 3.4CamaroCDOG
    • Feb 2008
    • 18
    High/Fast Idle
    ok i searched around and nobody listed the problems like im having
    ok so in the morning when i crank up it goes up to 1500( 1000 is normal) if i let it warm up and drive it it goes back down to 1000 while in drive and reverse but 1500 in park and nuetral... If i crank up when its warm already it will stay at 1500 in all gears it is hard to stop at lights because the wheels are still spinning....wat could be wrong?
    Also, i changed the IAC, TPS, and the IAT sensors but it continues to rise to 1500 and i also have bad exhaust leaks
  • geoffinbc
    Iron Head Enthusiast
    • 5831
    Well 1500 is fine for cold startup and that is normal for a few mins. But it should not happen on warm startup. Check the engine coolant temp sensor in the intake manifold. Remove it, take it inside to room temp for about 1/2 hour and measure with an OHM meter. It needs to read 3400 ohms at 21*C(70*F). If it is off replace it.
    • 3.4CamaroCDOG
      • Feb 2008
      • 18
      i forgot to mention that i replaced that too
        • 9189
        Could be a vacuum leak if its happening all the time.
        • 3.4CamaroCDOG
          • Feb 2008
          • 18
          it doesnt happen all the time only sometimes in drive other times its ok in drive ive checked for vacuum leaks
          • geoffinbc
            • 5831
            It could still be a Vac leak. Just intermittent. My moms car did it when the PCV hose was cracked. It was reving to 3000RPM though LOL. It only did it the odd time.
            • 3.4CamaroCDOG
              • Feb 2008
              • 18
              lol ill have to check it in the morning
              how many vac lines are there
              i kno the pcv and brake booster wat other lines are there?
              • geoffinbc
                • 5831
                One to the inside of the passenger compartment, on to the vacuum canister and one to the EVAP system.
                There is a vacuum diagram under the hood of your car.
                • 3.4CamaroCDOG
                  • Feb 2008
                  • 18
                  ok ill check in the morning cause the PCV and brake booster is good i never knew about the passanger side 1
                  man its cold as hell here in chicago i hate workin on my car lol
