Fiero v6 knocking (Video Clip)
  • MetalMutantFiero
    • Mar 2004
    • 6
    Hi people!
    I just bought a -85 Fiero v6 GT
    and I have a problem with a knocking noise in the engine, it seems that it comes from the upper parts of the engine.
    Has anyone any idea what´s the problem
    You can download a short videoclip (5Mb) I did so you can se the engine and hear the knocking:
    Right click and Save As...
    (I'm Sorry for my poor english, Im from sweden)
    /Peter
  • robby1870
    Squaddoosh
    • 584
    That sounds a lot like what mine sounded like when I broke a guideplate, knocking a rocker off a valve......but, I dont know for sure what your problem is, but like you said, it is in the top of the motor...so thats a little better
    Robby Whitesell
    2006 Pontiac G6 GT
    1985 Toyota Pickup DLX
    • jmgtp
      • 1219
      I had a engine (was a 60* v6 just not a GM one) make a similar sound when there was a considerable amount of water in the fuel tank. It seemed to run ok other than the top end knock and required a lot of cranking before starting. A bottle of dry gas and some fresh premium grade fuel cured the knock within minutes. Something to check at least. I hope its something as simple as that and not mechanical damage. Good luck!
      1994 Corvette
      LT1/ZF6
      2006 Dodge Dakota 4x4
      3.7/42RLE
      • gpse3400
        • 1460
        Sounds like either excessive valve lash or an exhaust manifold/gasket/headpipe leak. Maybe even a loose spark plug.
        Lorenzo
        • MetalMutantFiero
          • Mar 2004
          • 6
          Hi !
          Thanx for your replys, It apperantly can be many differient things,
          so It's just one thing left to do... start dismantle the top(s) and hope it's a easy repair..
          I've bought the Chilton Fiero repair manual so lets hope for the best
          I'll be back with a report
          Thanx
          /Peter
          • MetalMutantFiero
            • Mar 2004
            • 6
            the knocking Fiwero Part2
            Hi there!
            I'm trying to identify some problems with the valvetrain.
            And it seems to me that the most rockers are kind of loose :/ I did take some video clips, With the engine in TDC 1 to TDC 6.
            First I did a up and down movement on the rockers then a left and right movement,
            you can view it here:
            Right click and choose Save as...
            I really don´t know how it´s suppose to be, so maby someone can identify a valve lash problem, and if it's a lifter problem or is it just a valve lash adjustment problem...
            I don't want to remove the lower intake unless it's really necessary ...
            A very big thanx to you all
            /Peter
            • MetalMutantFiero
              • Mar 2004
              • 6
              Knocking fiero v6 - Problem solved?
              Hi guys!
              well... I think I found what caused the Ticking/Knocking noise in my v6 engine, but I want your point of view also...
              One of the lifters to the nr 2 cylinder was totaly stuck, not in the bore but I could not push down the thing in the middle of the lifter.. I removed the lifter and try to press down the thing in the middle and it was impossible!
              I even put it at the floor and use a screwdriver trying to force the inside of the lifter to move... But the it was totally stuck at its highest point...
              There were no visible wear at the stuck lifter bottom end so the cam lobe is presumably good
              There were no problem at all with the other 11 lifters, I could move the inside of those lifters with ease..
              So what are you guys think, am I at the right track?
              Thanx
              /Peter
              P.S You who have'nt seen it, can look at the video clip here http://hem.passagen.se/mutant1/Fiero.html
              • geoffinbc
                Iron Head Enthusiast
                • 5831
                I would say so. May be a good idea to replace them all.
                • MetalMutantFiero
                  • Mar 2004
                  • 6
                  Hi there guess what!
                  I have just replaced the defect lifter and when I started the engine the knocking/ticking sound was still there maby I should have replaced them all but I could'nt find anything wrong with the other 11 lifters...
                  I adjusted the rockers by follow the Haynes manual directions.
                  What the f*ck is wrong?
                  /Peter
                  • dodgerunner
                    • Mar 2004
                    • 14
                    You say the lifter seemed stuck, did you compare to any others? I would hope these are hyd. lifters, and you can't normally push them in since they are filled with oil and should not leak down very fast. I would guess the others would be the same.
                    Don't know what your problem could be, but does not sound like lifter to me. Sure you don't have a rod knocking?
                    96 Intrepid, 95 Ram, 96 GP3100, 88FieroGT 85FieroGT3.4, 74Vet, 67Stang
                    • akira
                      • 45
                      That just sounds scary!! I had a similar problem on a ford 5.0L I worked on. The harmonic balancer was loose and a wrist pin was shot. I dunno about the rest of you but that doesn not sound like top end to me! I did have a knock like that (alot quieter though) in my S-10 but I pulled the motor before it got that bad. Turns out it was the crank. It was pounded out of round by over 0.060" aka junk. Good luck but I think you need to pull it.
                      Why pay someone to do the work, it costs alot and you don\'t learn s*^t!!!
                      • ouch1011
                        • Jul 2004
                        • 6
                        Almost sounds like piston slap to me...
                        • Banana
                          • Jul 2004
                          • 17
                          my fiero sounds like but its 10x worst and you cant take it above 2 grand or the car will shake like a madman. im gettting a new engine
                          • RacerX11
                            • 1060
                            My '84 X-11 2.8 had a knocking sound very similar, turned out to be a loose timing chain knocking against the timing cover. That sound is definitely not a lifter or valvetrain noise. I say either the timing chain, or a rod.
                            Marty
                            '99 Z-28 - Weekend Driver
                            '84 X-11 - Time and Money Pit
                            Quote of the week:
                            Originally posted by Aaron
