Fuel pressure 2.8 tpi
  • jim herlihy
    • Mar 2008
    • 2
    Hi, I am trying to identify what the nessary fuel pump pressure is for a 2.8 tpi this one appears to be a 89 camero, also is there a way to increase the pressure through the fuel injection return? I am using a ford truck 60 pd pump and yet when I test the pressure on top of the engine I am showing 32 pds.
    Thanks
    Jim
  • merlot566jka
    • Nov 2006
    • 570
    camaro
    32 psi?
    check the regulator, fuel filter, check the pump (usually ford crap doesnt work in gm vehicles!), do a leak down test to verify you dont have one injector letting loose
    2012 Chevy Sonic Turbo 6spd
