Im swapping a 3.1l multi port into my 85 fiero. The person who owned it before me had it setup to run on a distributor and to do that he had to flip the intake around the other way and changed/blocked off some things that i want to change back. I dont know how to post pics on here for so i can find out whats missing but things i no are that the TB vaccum port is blocked off and im getting the oil pump drive for it so and i want to flip the intake again. I dont know how hard this is because i really dont know much about this motor yet. thanks, andrew. Also any pics of a cleaned up 3.1l would help.
3.1l help
Tags: None
...and does anyone no what the tool is called that lifts the rocker arm so the push rod can be removed to put a new intake gasket on with out having to remove the rockers and reset the lash?
Don't know the name, but if you need any 3.1 MPFI pics, I can get you anything you need.
I have a 1990 Pontiac Grand Prix STE with the 3.1 MPFI. Just let me know what you need to see, and I will get the pics for you.Taylor
1998 Lincoln Mark VIII
