My 3100 Leaks a Quart of Oil Every Month
  • gpchris
    • Feb 2007
    • 477
    LIM gaskets were just replaced.. I think it may be leaking from the oil pan gasket. Where do these engines commonly leak oil??
  • 19Cutlass94
    • Apr 2005
    • 770
    Theres an oil pump drive seal O-ring thats very common for leaks. Its right under the TB on the block.
    3400/Getrag 284 5spd
    350/NV3500 5spd
    2014 Chevrolet Malibu LS
    • gpchris
      • Feb 2007
      • 477
      I hope its not leaking from the oil pump drive... That would suck.
      • PCGUY112887
        • Feb 2006
        • 1067
        It's not that bad, much better place to leak vs the oil pan. Once ya actually get to the oil pump drive all you have to do to replace it is unbolt a little bracket that keeps it down, get a screwdriver and pry the pump drive up and it comes out. Rip off old gasket, clean up, reinstall gasket, put some oil on it all and shove her back in!
        SpudFiles
        Theopia
        Enjoy life online.
          You should of replaced the oil pump drive shaft o-ring when you did the LIM gasket. That's like common procedure don't ya know?
          My oil pan leaks, but it doesn't lower the oil level significantly between oil changes. It's not even 1/3 of a quart low on oil when I change the oil.
          • gpchris
            • Feb 2007
            • 477
            Oil pan would be quicker and easier IMO. Dont you have to pull the heads to replace the pump drive seal?
              • 9186
              That's only on the DOHCs that you have to pull the heads...
              • gpchris
                • Feb 2007
                • 477
                Damn.. Should've done it while i was down there.. Possible to do without taking off the lim?
                • gpchris
                  • Feb 2007
                  • 477
                  Well thank guys for the help. Im gona take a look at it tomorrow and see where its coming from. if its the oil pan, im pretty sure i can get it done in a day.
                  • gpchris
                    • Feb 2007
                    • 477
                    Ahh hell looked at it today and theres oil all over the rear of the block. Starts around the oil pump drive...
                    • merlot566jka
                      • Nov 2006
                      • 570
                      go have a shop do an oil dye test, its pretty cheap. and youll know exactly where its coming from.
                      2012 Chevy Sonic Turbo 6spd
                      • gpchris
                        • Feb 2007
                        • 477
                        well considering my block is dry except for all around the oil pump drive seal i can only assume............................................ ........................................
                          But... You know what happens when you assume... :P
                          • 94GPGTP
                            95 Grand Prix GTP
                            • Apr 2007
                            • 593
                            gpchris.. are you in lowell, indiana??
                            Robert
                            New Rebuilt 3100
                            New Rebuilt 4T60-E
                            Exhaust
                            Drilled/Slotted Rotors
                            White
                            3" Magnaflow Catback
                            90 Pontiac Turbo Grand Prix
                            5 Speed Swapped
                            127,000
                            Spec Stage 3 Clutch
                            230,000 mile Getrag 282
                            Emissions Deleted
                            Brand new Engine 1,000 Miles
                            Fully Custom Built car
                            • 1988GTU
                              LB62LHObbqftmfw
                              • Nov 2005
                              • 2475
                              Why is this in the pushrod section? DOHC needs the rear head pulled off to replace the o-ring.
                              Pushrod 660 doesn't need the heads removed.
