3100, PLEASE help
  • defiant_one
    • Jun 2008
    • 5
    3100, PLEASE help
    I have a 94 GP with the 3100 in it. I have been having problems starting the car recently, which was overcome by turning the key back to the AUX. position or by pushing in on the lock cylinder as I turned the key forward. Didn't happen all the time or with any rhyme or reason, just happened. Now it does nothing. No starter sounds, no fuel pump sounds, no dash lights, dome light goes out and stays out, no radio, nothing. Basically, after trying to turn it over, I lose ALL electrics. I replaced the $100+ ignition no change, checked all fuses, checked both battery cables and cleaned very minor corrosion off, pulled starter off and had checked with solenoid and they worked. I'm thinking possibly C.P.S. or neutral safety switch next. Any help please, I'm 400 miles from home stranded, and need to get home ASAP. Thanx in advance.
  • defiant_one
    • Jun 2008
    • 5
    *edited to add* also has brand new die hard battery in it less than a week old
    • 94GPGTP
      95 Grand Prix GTP
      • Apr 2007
      • 593
      well if you are not getting anything out of the car when key is turn forward i would be leaning toward the ignition switch.. It's mounted on top of the steering column.. I believe you already replaced that.. Did you check the under the hood fuses next to the radiator cap and the overflow tank?? The fuses are quite large!! Did you check the AUX terminal for corrosion too?? Hoping i can help ya out..
      Robert
      New Rebuilt 3100
      New Rebuilt 4T60-E
      Exhaust
      Drilled/Slotted Rotors
      White
      3" Magnaflow Catback
      90 Pontiac Turbo Grand Prix
      5 Speed Swapped
      127,000
      Spec Stage 3 Clutch
      230,000 mile Getrag 282
      Emissions Deleted
      Brand new Engine 1,000 Miles
      Fully Custom Built car
      • defiant_one
        • Jun 2008
        • 5
        Yes, I replaced the switch and did check ignition fuses, but wasn't sure if any of the relays had anything to do with it or not. And yes, I checked the Aux terminal, and cleaned it just to be safe
        • 94GPGTP
          95 Grand Prix GTP
          • Apr 2007
          • 593
          Hmm.. Sounds Strange.. So nothing happens when the key is turned? Its like if there was no battery in the car??
          Robert
          New Rebuilt 3100
          New Rebuilt 4T60-E
          Exhaust
          White
          5 Speed Swapped
          127,000
          Spec Stage 3 Clutch
          Emissions Deleted
          • defiant_one
            • Jun 2008
            • 5
            Exactly like that. Nothing what so ever happens except loss of electrics as mentioned before
            • 94GPGTP
              95 Grand Prix GTP
              • Apr 2007
              • 593
              Have you trid jumping the car?? Highly doubt it but its only worth a try but possibly a bad battery.. It can't hurt to try though.. I'll Think about it more and see what i can brew up.. But you got me stumped too..
              Robert
              New Rebuilt 3100
              New Rebuilt 4T60-E
              Exhaust
              White
              5 Speed Swapped
              127,000
              Spec Stage 3 Clutch
              Emissions Deleted
              • defiant_one
                • Jun 2008
                • 5
                I'll check the battery out tomorrow, hopefully that does the trick, and thanks for the help. Could it possibly have anything to do with the anti-theft mess?
                  • 9187
                  Are you sure everything was connected properly to the ignition switch? If you have power in any other position of the IGN switch, and everything goes dead when you try to start, I would lean towards that more than anything. Here is a diagram for a 94 Beretta starting circuit, which should be fairly similar to yours...
                  • 3100 MPFI
                    • 1522
                    Okay. A friend of mine just went through what sounds like the EXACT SAME THING.
                    For him, the NEGATIVE BATTERY CABLE was messed up, but what I would do is check to see if your UNDERHOOD ELECTRICAL CENTERS Are even getting power.
                    The MAXI FUSES should have power at all times.
                    Pull out 1 or 2 maxifuses, then use a voltmeter, or multimeter to see if you are getting power at all. His Grand Prix was an older one, but it was the PASSENGER SIDE fuse block that was not getting power, and just like yours, he would turn the key on and NOTHING.
                    Taylor
                    1998 Lincoln Mark VIII
                    • talon2swords
                      • Dec 2007
                      • 132
                      Yeah, maybe check the chassis and engine ground wire(s). I remember we had this problem on an old car a long time ago.
                      • SuzukiGhostRider
                        Beretta Freak
                        • Apr 2008
                        • 118
                        I agree. Check to see if you're even getting power to the fuse center. If not, I would also check your ground connection at the chassis/block.
                        EDIT.
                        LoL, same idea, I took too long to post.
