my car is revving to 7k rpms very easily???
  • no_doz
    • Sep 2005
    • 912
    car in sig, it revs to 7 pr 6800 before shifting when i run i get on it-is this normal? and if not can you guys give me a clue as to why its doing this?
  • Andromeda451
    • Mar 2007
    • 14
    Hi rev
    No,
    No it doesn't sound normal, it sounds like the transmission may be slipping. Check fluid level, hot engine. Check the modulator vacuum line for leaks etc. What is the quality of the shifts under light throttle versus LEAD foot.?
    rgds,
    A451
    Andromeda451
    Phx, AZ
    99 Lumina LS
    92 Jetta GLi16V
    78 Porsche 924
      Maybe someone swapped a crazy hybrid or a DOHC in there when you weren't looking?
        It won't be for long..
        Sounds like a trans prob to me as well...
        • no_doz
          • Sep 2005
          • 912
          the thing is it doesnt slip-it just goes high RPMs when i run it hard as hell-but there is -absolutely- no slipping. under regular or aggressive driving situations everything is perfectly normal, but at no point does the trans slip.
            Live life 3.7mi at a time
            • 4555
            1991, didn't you have a vac line going to the manifold from the tranny? If this line is pinched/cut/unplugged will cause that problem.
            • no_doz
              • Sep 2005
              • 912
              its actually a 1990, i found this out because i just found the title recently :S but unless i have it at 3/4 throttle or more it shifts perfectly.
                maybe some adjustment to the TV cable?
