Where are teh HD dogbones?
  • cutlass supreme FE3
    • Nov 2008
    • 225
    I have been going through these dogbones every 6 months at the local autoparts.
    Some company out there must be making something that will last a few years?
    Live life 3.7mi at a time
    • 4555
    Are you breaking them, or is the rubber wearing? You can replace the rubber bushings with poly.
      • Nov 2008
      • 225
      the black rubber inside is broken or moves too much.
      where do you get the poly replacements? I definiely will need poly if they do not give out.
        • 4555
        Energy suspension. Measure the hole in the dogbone and match up what they got.
          • Nov 2008
          • 225
          the hole of the dogbone is not completely though.
          there is a flange in the middle.
            • 4555
            That's OK. Take the rubber out, and you should be able to find a similar bushing.
            We made some tranny dog bones a while back at the shop, Issac Hayes designed them and they used energy poly inserts...
              • Nov 2008
              • 225
              rubber bushings are just too soft
                My dogbones are actually for the engine, not trans.
                But yeah go to www.energysuspension.com and check out the universal flange bushings. Measure and I'm sure you can find something. If the cast aluminum breaks from the poly, then you could probably find steel dogbones from another similar car maybe newer model. I know the later models had steel front dog bones.
                • LeftVentricle
                  Right aorta
                  • Oct 2005
                  • 507
                  I had my shop make one out of a 1/2 x 1-1/2 x 2 piece of steel bar welded between two chromoly bushings. My engine does not move.
                  I got the bushings from a 4x4 shop. They're not cheap though—I paid $33 for the two of them, but got the steel from scrap and had one of the welders do it on the side real quick.
                    • Nov 2008
                    • 225
                    If you do not have to replace them every again then i say it was a well spent 33 dollars
                    • PCGUY112887
                      • Feb 2006
                      • 1067
                      I am surprised no one has said this, but shouldn't we wonder why they are wearing out so fast? Do you have other mounts worn/broken causing excessive wear on the dog bones?
                      SpudFiles
                      Theopia
                      Enjoy life online.
                      • 93grandprixse
                        • Aug 2005
                        • 35
                        yea, now instead of the bushings wearing out, your just going to snap it and do worst damage...
                          • Nov 2008
                          • 225
                          i got like 8 dog bones that all have one bushing on each that usually gives out.
