Compression for LE2
  • Braddock
    • Nov 2008
    • 42
    Resolved : Compression for LE2
    What should my 23(this month) year old LE2 engine score on a compression test? (average)
    • 9191
    I'd guess somewhere around 100-115, and then all cylinders within 10% of each other.
    • Braddock
      • Nov 2008
      • 42
      Really?! So my 130-140 is exceptional?!?
      • Braddock
        • Nov 2008
        • 42
        btw, i cant find the marks on drivewheel to set timing...
          • 9191
          130-140 is pretty good for that old of an engine. I know 3x00s usually crank between 140-160. So I would say you are just fine.
          As far as marks on the pulley, I can't help you out.
          • torq455
            If I only had money!!!
            • 1615
            3x00 are that low!? my 3.1 with 126K had 173-180 psi., which is within 2.8% of each other.
            Andy
            fastest 1/8: 10.19@ 67.17
            fastest 1/4: 16.16@ 82.70
              • 9191
              I've seen higher, but its not required to be that high.
              • Braddock
                • Nov 2008
                • 42
                I still cant seem to find timing mark, but i looked at other cars of same year/engine/ect. and the distrib basically alligned perfectly with the rear head, so I know its probably pretty close. I think...
                Can you mark this as resolved?
