Power Steering Vibration.
  • Braddock
    • Nov 2008
    • 42
    Resolved : Power Steering Vibration.
    My car drives again!
    But...
    My power steering is vibrating and the engine sounds strange when i turn wheel. This problem started up at the exact same time as engine problems. Would this just be caused by weakness of engine due to bad fuel mixture?
    PS.
    Whats a good method for setting a good low idle?
  • TDIXON
    Red Monster...
    • Dec 2007
    • 102
    Is your serpentine belt tight/or wore. You may also have air in the power steering system as well.
    1992 Buick Skylark 2.3L 1996 GrandAm 3100 SFI 1996 Ford E150 Conversion 5.8L
    • Wiz85
      N/A all the way
      • Feb 2008
      • 48
      If you need a PS pump, let me know, I just pulled mine off because I don't need it.
      Eric
      • 55trucker
        • 213
        Did you have to put a rebuild kit including new floats into that flooding carb?...the idle should be set at the factory.....is the idle rpm off the OEM spec?
        91 LQ1 GP GT
        • Braddock
          • Nov 2008
          • 42
          hey, thanks for the help. I figured it out. Bad valve lash causes 2 cylinders to be dead. and thus the power steering was putting too much load on weakened engine and the whole system misbehaved. it all cleared up when lash was readjusted.
          • Braddock
            • Nov 2008
            • 42
            RESOLVED
            • PCGUY112887
              • Feb 2006
              • 1067
              You didn't notice 2 dead cylinders before your power steering pump bogged the motor?
              SpudFiles
              Theopia
              Enjoy life online.
