Where do I find the esc module?
  • 3400fierogt
    • Mar 2008
    • 3
    I have megasquirt II installed on a '03 3400 in a fiero and I want to hook up my knock sensor (the knock sensor is off of a '93 z24 with a 3.1). I need an esc module, and I've got a '88 z24 for parts, but I don't know where to look for it and its -30c outside so I'd like to know before I go searching for it.
    Thanks
    '86 fiero-'03 3400 running on megasquirt II v3.
  • x-thumpr-x
    Fieronut3400
    • Feb 2004
    • 31
    The knock sensor hooks up to the ECM. I'm using a 7730 ECM on my 3400 conversion, but using a knock sensor out of a 91 Z24 (3.1L)
    87 Fiero GT
    3400
    14.217 @ 157 KMP
      • 9191
      The ESC module will be part of the PROM. So you'll have to take the PROM (MEMCAL) out of the ECM. Not sure what you will do with it after that, since you are running an MS though...
      • 3400fierogt
        • Mar 2008
        • 3
        I had the knock sensor connected directly to the ecm when I was running the 7730, but when I pulled the 7730 I thought maybe I made a mistake (I wired that in 7yrs ago). Anyways the megamanual makes it sound like it was used on all gm vehicles. I guess I'll try and find out what it did come on.
        Thanks
