1993 grand prix 3.1 help!!!!!!!!!!!!!!!!!!
  • terry1366
    • Feb 2009
    • 1
    i just bought a 1993 grand prix with a 3.1 wont run the guy said he had it running at idol at the car just stoped it turns over and has fuel but no spark im thinking crank sensor i have a new one but where the heck is it on this car anyone have a diagram oh this or an idea ???????????????????
  • 3100 MPFI
    • 1522
    Needs to be in the PUSHROD section.
    Crank position sensor is located on the rear of the engine (the side facing the firewall). It is a PITA to do. There is also the risk that when you try to remove it, it will break off, and have a big hassel to get it out.
    I will try to get a pic of where it is for you when I get my scanner reloaded.
    Taylor
    1998 Lincoln Mark VIII
    • 89Hatchback
      • Feb 2009
      • 39
      Ugh. I just went though that with my 2.8. When you try to pull it out, I'd suggest spin it and spin it some more as you pull on it. I went with a screwdriver to try and pry it out and broke it up. Ended up having to drop the oil pan to push it out.
      The problem is the end swells up a bit and the usual crud on it prevents it from coming out. Try to spin it to wear all the crud off, otherwise there's a good chance you'll need to drop the pan.
      • 3100 MPFI
        • 1522
        I thought I had a better pic, but this one will have to do for now.
        This is the BACK of the engine. This is actually on a 3.4 DOHC (that is why the alternator is on the back), but the Crank Position Sensor is located in the same spot on the 2 engines.
        Taylor
