poor milage 86 2.8l
  • kanga19
    • Apr 2004
    • 15
    poor milage 86 2.8l
    HELP!!!!!
    I have a 1986 s-10 4x4 with a 2.8l automatic trans
    my fuel milage bites big time. currently @ 16.76 miles to the gallon
    need some ideas as to what is should be and what may cause such poor milage
    SSDD (Same Sh*t Different Day)
    1986 S-10 2.8L Auto 4x4
    EGR Modification
    4.3l tbi unit w/ spacer.
  • geoffinbc
    Iron Head Enthusiast
    • 5831
    Hmm. First change the fuel filter and do a tune up. Make sure base timing is at 10* BTDC. Check out the tire pressure and be sure the brakes are not dragging.
    • kanga19
      • Apr 2004
      • 15
      timing is set at 10* btdc and i installed a new fuel filter when i put the new engine 6000km ago. the brakes arn't sticking already tought of that. also i am only getting 8* total advance when you go from idle to full throttle.
      EGR Modification
      • geoffinbc
        • 5831
        Ignition module is probabally toast. Or you have a knock sensor circuit problem.
        • kanga19
          • Apr 2004
          • 15
          where on the engine is the knock sensor located
          i can't find it for the life of me.
          EGR Modification
          • geoffinbc
            • 5831
            It is on the back side (nearest the firewall) it is screwed into the water jacket. It could possibly be on the front of the car depending on the model.
            • johnc
              • Jan 2004
              • 79
              Doesn't an 02 sensor failure cause a full rich condition? Do a search online for the 02 sensor operation explanation
              • akira
                • 45
                almost 17 mpg doesn't sound far from normal for city driving, or maybe I am just used to shit fuel milage. It's an under powered engine pushing a 4 spd auto AND a transfer case! It not a Golf TDI. Are you getting that all of the time even on the highway? Do you still have a cat and an egr pump? Axe those and you will notice a difference
                Why pay someone to do the work, it costs alot and you don\'t learn s*^t!!!
                • bvr775
                  • Jun 2004
                  • 33
                  17mpg is good for a 2.8 4x4 in a 1st gen s-10.your asking a 90hp engine to move close to 3400 lbs.3600 lbs if you have the stiffened full ladder frame that came with some of the 4x4 packages.
                  Do u have stock size rims and tires? have you done anygear changes.
                  Raceing a ricer is like running in the specail olympics. Even if you win your still retraded.
