RWD 3.4, out of car, should I replace the LIM?
  • 427v8
    • Jun 2006
    • 28
    It's a '95 iron head out of a Firebird, 130,000 miles. Ran good in the car it was pulled from, I saw it.
    I'm putting it in a '29 dodge 4 door.
    So while I'm cleaning it up, should I just go ahead and replace the LIM?
    Is there anyway to tell if the gasket has been replaced already?
    What I know is;
    *Some one was in the engine, 3 exhaust manifold bolts were broken off ( amazingly no exhaust leaks )
    * water jacket looks clean, as viewed through the thermostat hole
    * I can see a metal gasket sticking out from between the intake and the heads in the corner.
    *The front and rear of the intake is sealed with a bead of black RTV
    * the UIM gasket was hard and brittle.
    *The valve cover gaskets are cork and black RTV
    Thanks!
    Keith
  • geoffinbc
    Iron Head Enthusiast
    • 5831
    Well if your using the engine as a donor it never hurts to freshen it up. The iron head gaskets are not leak prone like the Gen III engines.
