Gas odor from FP test port?
  • Brad_Olson
    • Dec 2007
    • 28
    Yesterday my '01 Impala (3400) was in the shop because it was running poorly. The problem turned out to be a bad cat converter but as part of the diagnostic process the fuel pressure was tested. Today I noticed a strong gasoline odor when I drove to work, and when I checked under the hood I noticed that it was strongest around the pressure test port and the port was uncapped.
    Does the port have an internal Schrader-style valve that would allow a little bit of vapor to get by? My guess is that the valve actually stops fuel from spewing out while the cap acts as a second-level safety device and vapor barrier. I'll probably go to NAPA at lunch and pick up a rubber or plastic cap to use temporarily until I either retrieve the missing cap from the shop or buy a new one.
    Am I on the right track here? Thanks!
    Brad
    • 9191
    Yes, the port is a schrader valve. Not sure if it would allow vapors to pass. Most likely guess would be that whoever did the maintenance dumped a bit of fuel while connecting/disconnecting the pressure tester and didn't bother to clean it up.
    • Brad_Olson
      • Dec 2007
      • 28
      After driving around a bit at lunch the fitting was wet, so right now it looks like the Schrader valve might not be sealing 100%. I picked up the cap at the shop on the way home this afternoon so hopefully it'll solve the problem.
      For all I know the valve might've been faulty from day one and all this time the cap's been preventing any leaks.
      Brad
        Live life 3.7mi at a time
        • 4555
        You can replace the valve easily with a tool that costs a couple dollars. I wouldn't suggest just capping it without at least putting teflon tape around it. Flamable and hot materials don't mix nice, ask Brad
        • Brad_Olson
          • Dec 2007
          • 28
          Hmmm...good point.
          GM doesn't sell the cap separately, only as part of a kit that also includes a new valve. $40 or so, but that's a small price to pay compared to replacing an entire car, even if it is just a plain-jane Impala.
          It should be good and dry by morning so I'll keep an eye on it tomorrow.
          Brad
            • 4555
            $40?
            You can buy the tool and a replacement valve for less than 1/2 that It's the same tool/valve as whats in your tire stems, just make sure the oring color is the same. In fact, the valve may be loose, and is fine...
              • 9191
              Heat and flammable liquids equals...
                • 4555
                Brad, naw, that's just the easy way to strip all the insulation off your wiring harness
