Code 43 and running hot
  • LeftVentricle
    Right aorta
    • Oct 2005
    • 507
    1989 Celebrity, 3.1 MFI. I have a code 43 and I'm not sure what it means. According to the internet:
    Code 43: Electronic Spark Control Unit
    The ESC retard signal has been on for too long or the system has failed a functional check.
    It doesn't occur when the car is cold. Once operating temperature is reached the light comes on and idle speed and performance drops. Will also run hot if stuck in traffic. I know the cooling fan works, because I have it wired to be on with ignition, so the high temperature boggles me. (The reason for the direct cooling fan wiring is because it stopped coming on altogether some time ago, even with a new relay and motor.)
    Suggestions I've received range from using higher octane fuel to replacing the MEMCAL to replacing the EGR valve and thermostat. Any validity to those?
  • LeftVentricle
    Right aorta
    • Oct 2005
    • 507
    Nobody wants to help me out here, eh?
    • 1988GTU
      LB62LHObbqftmfw
      • Nov 2005
      • 2475
      Replace/Inspect the knock sensor circuit. Your engine is pulling timing causing it to work hard and most likely causing higher ct's. Also if your trans is slipping, that too will contribute to higher engine temps.
      • LeftVentricle
        Right aorta
        • Oct 2005
        • 507
        Dammit, I bought a knock sensor a while back, fully intending to install it, then promptly forgot. Bonehead.
          Lol yep, that's probably it.
          • LeftVentricle
            Right aorta
            • Oct 2005
            • 507
            No, I didn't forget to install it. I returned it for food money. Bought a new one. Will install tomorrow so I don't burn myself.
            • 1988GTU
              LB62LHObbqftmfw
              • Nov 2005
              • 2475
              I might be able to snag you a junk yard one .... wont cast you 40 + dollars. lol
              • LeftVentricle
                Right aorta
                • Oct 2005
                • 507
                Thanks for the offer, I already bought and installed a new one. Car runs fine now. Thanks guys, wish I had done this long ago. The one I pulled out definitely looked like it was original, so I'm impressed it lasted as long as it did.
                • LeftVentricle
                  Right aorta
                  • Oct 2005
                  • 507
                  Still running hot when idling for protracted periods, but will cool off and stay cool while cruising.
                  • 1988GTU
                    LB62LHObbqftmfw
                    • Nov 2005
                    • 2475
                    How new is your rad? How old is your T-stat? Still getting that code?
                    • LeftVentricle
                      Right aorta
                      • Oct 2005
                      • 507
                      Code is gone since I put in the knock sensor. Radiator was replaced last year. Thermostat was replaced last month with a 180* unit. Cooling fan is hard-wired to be on any time the key is in the ON position.
                      EDIT: I spoke to my mechanic briefly today about this, seeing if he thought it might be the water pump. He said that the only way the water pump would be bad with the symptoms I described is if the impeller fins are worn down to nubs, which is, in his opinion, quite rare.
                      • 1988GTU
                        LB62LHObbqftmfw
                        • Nov 2005
                        • 2475
                        Is the fan wired correctly?
                        • LeftVentricle
                          Right aorta
                          • Oct 2005
                          • 507
                          Not sure what you mean by this. The fan comes on with the ignition and stays on until I shut the engine off.
                          • 1988GTU
                            LB62LHObbqftmfw
                            • Nov 2005
                            • 2475
                            Is the polarity correct?
                            • LeftVentricle
                              Right aorta
                              • Oct 2005
                              • 507
                              It blows in the right direction, if that's what you're getting at. Otherwise, I don't know, I didn't wire it, my mechanic did. Also, if I run the air conditioning, it will cool off in a hurry.
