I have just finished replacing the transmission, and doing the lower intake manifold gaskets in my 95 monte 3100. Upon starting the engine again for the first time after doing the manifold gaskets I end up getting an oil pressure light after 30-60 seconds after starting up the engine. I did change the o ring seal for the oil pump drive when I did the LIM, but I can't imagine that I did anything wrong there, it was fairly straight forward remove the shaft and change the oring, I was sure the oring was in the exact same groove it came out of. Reinstalling it I simply dropped it in the hole, moved it a little until it fully dropped in and worked the oring down, installed the hold down and bolt.
Other things I noticed or you might want to know:
The engine doesn't sound like its running without oil. Its noisy, but its always been noisy for as long as I can remember having the car, and long before I did this work to it.
I did use 10-30 oil instead of 5-30, Its all I had handy when I was ready to fire up the engine and I planned on doing a filter and another oil change after the engine had been running for 15 minutes or so. Could something like that cause the low oil press light?
It doesn't happen right when I start the engine, usually doesn't come on for 30-60 seconds after. It slows fades on, and doesn't dissapear when I rev the engine
Peering into the oil fill cap hole I can see the bottom part of the heads filling with oil it looks like.
Oil and coolant levels are normal, doesn't appear that coolant or anything is getting into the oil.
I did pressure wash the engine while it was out and quite possibly nailed the oil pressure sending unit with the sprayer.
I did NOT do the LIM because they were leaking, they were not, and I never had a situation that coolant go into the oil while the engine was running. I only did it because the engine was out and I'm sure glad I did as they were indeed factory plastic ones with over 100k miles on them and starting to break down.
So after hearing all this what are your suggestions? Could this be something as stupid as using 10w30 instead of 5w30? Is it possible to connect an actual oil pressure gauge to the engine to see what its actually at, if so, anyone know the size of the fitting off hand? Could I have screwed something up when installing the oil pump drive? Is it really possible to screw that up?
