Camshaft Gear Timing
  • cjvolcom
    • May 2009
    • 14
    I'm replacing the timing chain on a 3100 in my 97 Grand Am, and the is no timing marks on the camshaft gear. What would be the correct positioning using the key as a reference point? for example should the key be pointed straight down twords the crankshaft? straight up away from it? of to the right? or what. Thanks in advance.
    • 9191
    Look for dots on the gears and make sure they are aligned, as shown in the above image.
    • cjvolcom
      • May 2009
      • 14
      So correct me if I'm wrong here, the camshaft alignment pin should be a 3 o'clock and the sprocket locator hole at 6 o'clock as shown in the graphic, or am I missing somthing?
      Are they reffering to the sprocket locator hole as the "timing mark", because I have been looking for a dot on one of the teeth like the one on the crankshaft, but no such dot exists.
      Thanks agian, I really appreciate it.
        • 9191
        Yes, the locator hole is what needs to line up with the dot. When this is done, the crank and cam keyways will be as shown in the diagram.
