TGP Turbo exhaust gasket sourcing
  • Daguse5853Z
    Here's yer sign
    • Nov 2003
    • 155
    Where can I buy the gasket that seals the turbo to the crossover pipe and also the gasket that seals the turbo exhaust to the downpipe?
    95 Z26 3400/OBDII/GETRAG
  • 1988GTU
    LB62LHObbqftmfw
    • Nov 2005
    • 2475
    You ideally don't have gaskets there. If the surfaces are warped, you should have them resurfaced and torque to spec. Otherwise, a T25 gasket is possible for the crossover to TC, and I think you can get lucky on ebay for a downpipe housing gasket. You just need to make sure the pattern is right.
    • RedZMonte
      • Feb 2004
      • 1378
      No gaskets from the factory on the TGP t25's. but you can get them aftermarket from just about any turbo site... here is the 1st things that came up when i searched google. it should be a standard 4 bolt T2 inlet gasket and a standard 5 bold T2 outlet gasket. hope this helps
      T25 turbo inlet/outlet gaskets:
      http://www.jegs.com/i/Edelbrock/350/15003/10002/-1
      S
      Shane "RedZMonte"
      1992 Lumina Z34-VIRGIN (RIP)
      1992 L67 Lumina Z34 (SOLD)
      1990 Turbo Grand Prix (SOLD)
      • 60dgrzbelow0
        "Yes... I AM IRONMAN..."
        • Mar 2009
        • 1344
        The REMFLEX Gasket Products are also superb...and seal amazing well in fact... Look here for their on-line catalog:
