New Member
  • BadGrandPrixSE
    • May 2004
    • 47
    New Member
    Whats up Everyone.
    New member. Just wanting to ask a question. How hard is it to change the head cover gaskets.
    William
    1BadPrix
  • robby1870
    Squaddoosh
    • 584
    by head cover....do you mean valve cover? Or head gaskets themselves?
    Robby Whitesell
    2006 Pontiac G6 GT
    1985 Toyota Pickup DLX
    • BadGrandPrixSE
      • May 2004
      • 47
      Head Gaskets. Sorry
      1BadPrix
      • Mitch DOHC
        • Jan 2004
        • 261
        well that depends on what moter u r changing head gaskets on........ preaty much any moter is a job but push rods are less involved than the DOHC
        1994 Cutlass Supreme Convertible 3.4 DOHC
        1969 Oldsmobile 442
        1997 Chevy Tahoe
        http://members.cardomain.com/mperkins442
        • BadGrandPrixSE
          • May 2004
          • 47
          Its the 3100. I was thinking of changing the head gasket and everything else from the gaskets to the top of the engine. As long as there isnt any problems when i do tear it apart. How much do the head gaskets, vavle cover gaskets and the intake manifold gaskets cost anyone.
          William
          1BadPrix
            • 9191
            You can get a head gasket kit from Fel-Pro that has everything you need from the head gaskets up for around $100. Add in new head bolts for another $20 or so. The first time I did the job, it was 2 full days to get it all swapped out.
            • BadGrandPrixSE
              • May 2004
              • 47
              Ok Bzopi,
              When i do tear it apart is there any specific things i should look for with some of the parts out like the valves or pushrods or the cylinder head for warpage. I am very new to this bu i have friends help when i go to do this. I will try and do the work in 3 to 4 days straight with my vacation time. Also is there anything major that i could screw up if i do do this.
              Thanks
              William
              1BadPrix
              • robby1870
                Squaddoosh
                • 584
                If you are changing the head gaskets b/c you one blew, I would get the heads checked for warpage and decked if they are warped
                Robby Whitesell
                2006 Pontiac G6 GT
                • BadGrandPrixSE
                  • May 2004
                  • 47
                  Robby1870,
                  I dont think that it has been blown. I still drive it and it doesnt overheat or use coolant or anything. I was just going to change them because i am coming up on 150K and i just wanted to get some stuff done to it.
                  William
                  1BadPrix
                  • robby1870
                    Squaddoosh
                    • 584
                    I gotcha. Everything is pretty straight forward. Might be a good idea to run your valves while you got the heads off, not that they will need it, but since your doing a "tune up" it couldnt hurt.
                    Robby Whitesell
                    2006 Pontiac G6 GT
                    • BadGrandPrixSE
                      • May 2004
                      • 47
                      Thanks All. I will keep everyone posted on how it goes once i get to doing the job. Thanks
                      William
                      1BadPrix
