Gasket Part Numbers
  • Weatheralls Auto
    Spinning out of control
    • Dec 2009
    • 536
    Gasket Part Numbers
    Hmmmm My Search queries coming up blank (probably need more coffee lol)
    Looking for the Part numbers the gaskets for the LIM and UIM & Rockers Covers (metal LIM) for the 3500 LX9?
    Also for the Timing Cover (can remember which is better, Brown?? )
    As of April 2
    Engine: 2006 SV6 3500 LX9
    Trans: 2002 Getrag F23 5speed
    Injectors: #36 GTPs
    TB: 65mm TCE
    Maf: 1999 3400 Montana.
    Beverages: Ice Cold CANADIAN.
  • Weatheralls Auto
    • Dec 2009
    • 536
    My Supplier has Felpro MS9013T(Kit has LIM/UIM and RockerCover Gaskets) listed, he says is the new Update but does not know if it is metal or not?????
    Also, can't find the post I read about Front Cover gasket, about Black and Brown?
    Which is better? (Think I read Brown? )
    Anyone have the PN for that?
    As of April 2
    Injectors: #36 GTPs
    TB: 65mm TCE
    • geldartb
      The Situation
      • May 2004
      • 1994
      yep its the metal ones. same ones i bought before.
      FEL-PRO Part # MS98013T More Info {Intake Manifold Gasket Set}
      OHV engine; Valve cover gskts. & Upper set incl.; PermaDryPlus® int. manifold gskts. incl.
      do you mean the timing cover gasket. last time around i used the fel pro one. iirc you get the water pump and a few other gaskets in the set with that.
      99 Grand Am GT
      1357 cam 227 233 .050 dur
      515 515 lift 112 lsa
      • Weatheralls Auto
        • Dec 2009
        • 536
        Awsome, thanx,
        Now just have to find the best Front Cover gasket and I am all set lol.
        As of April 2
        Injectors: #36 GTPs
        TB: 65mm TCE
        • geldartb
          The Situation
          • May 2004
          • 1994
          5.08 from rock auto
          FEL-PRO Part # TCS45828 More Info
          OHV engine; w/o Sleeve 'N' Seal
          99 Grand Am GT
          • Weatheralls Auto
            • Dec 2009
            • 536
            Ahhhh, My guy find that number, he only lists TCS46088
            Wonder if its a Canadian Thang lol?
            As of April 2
            Injectors: #36 GTPs
            TB: 65mm TCE
            • geldartb
              The Situation
              • May 2004
              • 1994
              well yeah that will work its the set for the 3500
              the one i posted was for the 3400
              99 Grand Am GT
              • Weatheralls Auto
                • Dec 2009
                • 536
                Cool, thanx, just wanted to be sure!
                As of April 2
                Injectors: #36 GTPs
                TB: 65mm TCE
