Olds Cutlass Supreme 3.1 Stalling/Idling Problems
    Two problems working together is never fun. At least you have one taken care of and can get this other one knocked out in no time
    • 13btJim
      • Jan 2010
      • 12
      I changed out the ICM and still am having hard starts and the car is still running extremely rich. I am not sure about the mpg''s but I would guess around 12-13 mpg, so it is running very rich. The car is also only doing this when it is at operating tempurature.
      -1987 Mazda Rx7- Borg Warner S475 and all of the supporting mods....not slow
      -2001 Dodge Ram 2500 Diesel- 4" MBRP turbo back, Edge Drag Comp...coal roller
      -1998 Buick Regal GS- Daily Driver
      -1991 Olds Cutlass Supreme- Other Daily Driver......money pit
      • 13btJim
        • Jan 2010
        • 12
        Somewhat of an update, I replaced the spark plugs again, and spark plug wires.....again and cylinder 6 coil. Also I changed the O2 sensor. Still not much of a change. The car is not firing properly on cylinder 6. The compression is fine on this cylinder, there is spark, we put a node light on the injector and it is firing, but there is a misfire between 1500-2000 rpms. The cylinder is also loading up with fuel. Anybody have any ideas? Could the ECM be bad? The wires going to the injector is fine. I dont know what else it could be.
          • 9189
          Injector could possibly be stuck open if the cylinder is filling up with fuel.
          • 13btJim
            • Jan 2010
            • 12
            I was thinking that too but we put a noid light on the injector and it seems to be fine....Plus I bought all 6 of them as newly remanufactured and they came with a flow spec sheet and what not. I will give the guy that I bought them from a call. He may be able to clear some things up. I am really stumped on this one, so stumped that for the first time in my life I might take a vehicle to a mechanic
              Maybe your ICM is bad?
                • 9189
                #22
                If you are able to read the codes, which it appears you are, swap the coils around and see if the misfire follows. That will tell you if its a bad coil or not.
                • 13btJim
                  • Jan 2010
                  • 12
                  #23
                  Funny thing is, is that I did change out the ICM and the coil on cylinder 6, no change really.
                  • 13btJim
                    • Jan 2010
                    • 12
                    #24
                    I did some more work this weekend on the car and discovered that the injector on cylinder 6, even being brand new, was no good. I pulled the injector out and was able to blow right through it without a problem, so at 40 psi of fuel pressure it would be pretty leaky. It fixed the problem and the car runs great again. Thanks for the help guys!
                      • 9189
                      #25
                      Woohoo for me! You can never guarantee a part is good, even if its brand new.
                      • Supreme Cutlass 1994
                        • Jan 2011
                        • 11
                        #26
                        Hey 3 things come to mind for me.
                        1) Pull the spark plugs, are they fouled ? or does they look like the engine is running lean ?
                        2) Idle relearn after any of the many things that you tried to correct your problem?
                        3) Any codes past or present ?
