3.4 Frankenbird Won't Start!
    I think the best news here is your friend is ok, but you being able to monkey with your car again is a good thing too
    • tkoforpresident
      Max
      • Feb 2009
      • 710
      #32
      yes of course.
      93 Firebird 3.4
      • tkoforpresident
        Max
        • Feb 2009
        • 710
        #33
        well, I failed miserably again.
        But I took it a lot better than usual. This whole situation with my friend has put things more in perspective and I've realized it's a blessing to be able to work on this crappy car, failing more often than succeeding, some times an absolute utter and complete failure, yet having the OPPORTUNITY to fail is precious while I am still alive.
        for the good news:
        I changed out the spark plugs, they were black as satan's heart and some were even a little wet and reeked of gasoline.
        for the bad news:
        I couldn't get a datalog (i was using v4). I was sure i had everything all set to go but as soon as i would hit "connect to ECM" I would get a "Could not initialize port" error code. I found through MUCH searching (this is windows 7 and it's not like Vista in this regard) that the com port was # 2 so i entered that in the tp preferences and yet i kept getting the same message. I startedt to think that maybe i needed drivers installed (for the aldl calbe) that i might not have had so i looked in my tuning folder and there was one driver setup so i installed it and it still gave me the same error code, even after restarting the laptop etc.
        I had no wireless networks to connect to so i couldn't look for more drivers, and either way i do not know if that is even the exact reason but since everything else looked quite in order i'm thinking that might be it.
        Thoughts?
        Max
        93 Firebird 3.4
        • tkoforpresident
          Max
          • Feb 2009
          • 710
          #34
          I'm told this is a Com port # issue but I found that it was com # 2, set it in TP's settings, and it still wouldn't connect =(
          93 Firebird 3.4
            if you're absolutely sure you have the COM port settings correct, then it may be time to contact mark mansur and figure out all of the possible reasons it could give that error. the only time i've ever seen it is if my cable wasn't plugged in, was plugged in but the connection was poor and would constantly connect/disconnect(or at least make the noises like it was), or i had port settings wrong.
              Live life 3.7mi at a time
              • 4555
              #36
              I got that when I first started when I hadn't downloaded and installed the USB driver.
              Mine is COM port 4
              • tkoforpresident
                Max
                • Feb 2009
                • 710
                #37
                Mine is COM port 4
                See, thats what i was thinking. Perhaps i hadn't downloaded the driver like i thought.
                I'm going to go right now to Moates.net and download the usb driver and see if that works.
                93 Firebird 3.4
                • tkoforpresident
                  Max
                  • Feb 2009
                  • 710
                  #38
                  Yup, just as i thought (and you John ), I didn't have the Moates USB driver installed. (don't know why, i could have sworn i installed it earlier)
                  no ones fault but my own.
                  all aboard the fail boat.
                  93 Firebird 3.4
                  • tkoforpresident
                    Max
                    • Feb 2009
                    • 710
                    #39
                    gonna go over today and try to get that data log for you guys.
                    hope for the best!
                    93 Firebird 3.4
                    • tkoforpresident
                      Max
                      • Feb 2009
                      • 710
                      #40
                      heres the log
                      93 Firebird 3.4
                        no attachments???
                        but 'grats on getting it to work.
                        • tkoforpresident
                          Max
                          • Feb 2009
                          • 710
                          #42
                          i mean HERE it is...
                          the car actually started and ran the whole time so i have a nice long one for you guys.
                          It would appear that replacing the spark plugs really helped out, and since i actually only replaced 4 this last time (please don't yell at me) i'm going to do the last two next time i go over.
                          A few things to note about the log:
                          It was idling high for a while and then settled down but would never stay right at one spot. It would fluctuate a good deal now and then.
                          There was more exhaust smoke than i'd ever seen in my life. It looked like i just sea foamed it!
                          I let it get up to operating temps before i ended the log.
                          And i set the fuel psi to ~ 42 while it was running (i THINK thats what i was told to put it at)
                          I'm really happy that it started and stayed on this time. We are on the right path!
                          93 Firebird 3.4
                          • tkoforpresident
                            Max
                            • Feb 2009
                            • 710
                            #43
                            here's the second log
                            i thought it seemed to idle healthier than ever before (at least audibly) but it did still shoot out lots of gas out the tail pipes (or condensation). the rpms stayed nice and tight and didn't go up and down too much so i was happy with that.
                            93 Firebird 3.4
                            • tkoforpresident
                              Max
                              • Feb 2009
                              • 710
                              #44
                              these vids were taken tonite while logging.
                              93 Firebird 3.4
                                • 4555
                                #45
                                A nice cam on iron heads just sounds so hot lol.
