Error codes p1655 and p1671
  • Schmieder
    • Dec 2009
    • 766
    Brief low down, installed a 97 Lumina pcm into a 96 grand prix. Checked all the wires and they are a match. The car has a newly installed turbo and needs tuned yet. It was sitting in a garage for about 2 months.
    It runs fine, start up is a little rough now but not a big issue. It idles fine but I still need to do an idle relearn. I think the hard start is due to a bad battery. I can hear the water sloshing around in the battery which isn't good. I still have warranty so that is ok for now.
    I am getting the error codes p1655 EVAP purge solenoid control circuit and p1671 Driver 4 line 1.
    I was wondering if these error codes have anything to do with the pcm swap. I have no fuel leaks that I can tell of.
    What should I do to help resolve these error codes?
    As I haven't much experience in the EVAP system. And the Driver 4 Line 1 seems to be a pcm error or wire to the pcm, but I double checked all the wires and the wire colors match up perfectly.
    Any advise is welcomed, thanks.
  • Weatheralls Auto
    Spinning out of control
    • Dec 2009
    • 536
    P1671 is Change Oil Lamp Ckt error.
    You have this error because you GP does not have this lamp in the IPC,
    Either use HPT to turn off DTC or you could even wire up your own change oil lamp.
    Ign feed to a bulb to C2 Term 8 ckt 803
    As of April 2
    Engine: 2006 SV6 3500 LX9
    Trans: 2002 Getrag F23 5speed
    Injectors: #36 GTPs
    TB: 65mm TCE
    Maf: 1999 3400 Montana.
    Beverages: Ice Cold CANADIAN.
    • Weatheralls Auto
      • Dec 2009
      • 536
      P1655 is also a Chevy only dtc, either turn it off, or wire a purge valve control from valve ckt 428 (dark green/white) to Pcm C1 Term 30
      As of April 2
      Injectors: #36 GTPs
      TB: 65mm TCE
      • Schmieder
        • Dec 2009
        • 766
        Man, you made my day. I can easily turn off the error codes through the HP Tuner.
        Easiest SES Light fix I ever had, haha.
        btw, I posted a video in the "She Started" thread.
