3400 LA1 intake gasket change
  • patgizz
    The Plaid Bandit
    • 1071
    i have my 3400 engine on the stand down to the longblock. i notice the intake gaskets go behind the pushrods so i need to pull the offending rocker arms and pushrods. are the rockers adjustable or do the bolts get torqued to spec(and if so what is the spec?). it is a 2000 engine, roller rockers.
    just need to know that then i can put it back together.
    • 9190
    They are torqued to spec. Not sure on the torque spec though....
    • patgizz
      The Plaid Bandit
      • 1071
      thank you, sir brad.
      anyone know the torque? newest factory GM manual i have with 3x00 in it is '96 so i dont think that will work.
      also need torque and sequence of lower intake bolts.
      • mfuller
        Mr. Common Sense
        • Nov 2003
        • 374
        According to my 2000 service manual, 14 lb-ft + 30 degrees.
        Matt
        • Zebe9
          • Mar 2004
          • 43
          3400 lower intake torque
          I would recommend also http://www.gm-v6lemons.com/-after (in)famous
          lower intake gasket problem in LA1 guys on this site have also GM Tech Bulletine with revised gasket and new specs for bolting.
          Zebe9
          Pontiac TS \'96 3400
          my way or highway
            • 9190
            http://www.60degreev6.com/forum/view...t=manifold+tsb
            • patgizz
              The Plaid Bandit
              • 1071
              haha its even a topic i started!
              i'm going to be so damn busy, looks like ive got a basement finshing job in a huge house. around 2300 sq foot of studs, electric, wall , acoustic ceiling, carpet, bathroom with ceramic tile, full custom wetbar, custom oak surrounded ventless gas fireplace.....thats probably 2 months of work for me, and with the cash i make off that i will definitely be finishing my car the right way.
