Still More Questions On My '99 3100 Teardown
  • Jogasz28
    • Dec 2006
    • 132
    I've tried to locate the Timing Marks on the Dampener but have been unsuccessful. I'm trying to not have to remove the front timing cover, dampener, as I only want to replace the head gaskets,
    Does anyone have a Pic of a 3.1 L82 with these marks they could send me?
    I searched the Net and found the following bad news:
    "The L82 ("M-code") was an updated, SFI version of the MPFI LH0, produced from 1993 through
    1999
    I checked the FM and found that when installing the rockers, the L82's have to be rotated to #1 and #4 firing position to set Valve Lash at no lash plus 1.5 turns.
    I'm trying to not have to remove the front of the engine. I don't even know if it can be dons as removing the Dampener looks pretty damn tight.
    As always, any help is much appreciated.
    JogasZ28
    jogasz28
    ______________
    '68 RS Camaro,
    Project '69 Camaro in the works
    '95 Monte Carlo Z34 loaded,
    '99 Monte Carlo LS
    • 9188
    Re: Still More Questions On My '99 3100 Teardown
    3x00 rockers don't require lash to be set. Just torque them to spec and go.
    Sent from my Devour using Tapatalk
    • Jogasz28
      • Dec 2006
      • 132
      Thank you!
      I saw somewhere during my surfing that the Rocker Arm Nut Torque Specs have been revised.
      If so, what are the new Specs?
      JogasZ28
      jogasz28
      ______________
      '68 RS Camaro,
      '99 Monte Carlo LS
      • Jogasz28
        • Dec 2006
        • 132
        I Removed a Rocker assembly from cylinder #1. Seemed like it need a lot more torque than 18 Lb Ft to remove it.
        Is a thread locker required on reassembly? I don't remember seeing it called for in the FM procedure.
        Also, the Spec Section of this Site calls for:
        Rocker Arm Bolt 89 +30°
        Other Sites have very different values.
        __________________________________________________ ____________
        Example:
        Connects: Rocker Arm To Cylinder Head
        Years: 1998-2002 Vote Record: Vote
        Note: 3100 - Rocker Arm Bolts - 2 Steps: 14 FtLbs(168 Inch Lbs; +30deg
        __________________________________________________ _____________
        The FM calls for 18 Ft Lbs. or 216 Inch Lbs. with no angle torque added.
        I want to use the latest procedure for reliability. It took too much work to get to these rockers.
        TIA,
        jogasz28
        ______________
        '68 RS Camaro,
        '99 Monte Carlo LS
        • Azrael
          Accelerating uphill in OD
          • Apr 2005
          • 763
          GM used two different rocker setups in the 3100's. The older, small-port version mostly used a pivotball rocker setup while the new, large-port one and the later year small-ports used roller fulcrum rockers. Torque specs are different for each.
          89lbs-in + 30 degrees for the pivotball rockers
          14 lbs-ft + 30 degrees for the roller fulcrum rockers
          1995 Grand Am SE
          • Jogasz28
            • Dec 2006
            • 132
            Appreciate the reply, the more info the better.
            I definitely have the later roller fulcrum rockers. It is a '99 3.1 Litre.
            The angle torque concerns me. Isn't it usually used for Torque-To-Yield bolts?
            I can see now how setting valve lash would be all but impossible given the setup.
            When I removed some of the rockers using my torque wrench, I had about
            337 Inch/Lbs (approximate because it was in reverse) to
            break them loose, so I was concerned.
            Should I use the FM Dealer Thread Sealant, or is there a cheaper alternative?
            I prefer Form-A-Gasker #2 on gaskets as it never hardens.
            But I'm open to suggestions on alternate thread sealants.
            Again, thanks to all for the help.
            jogasz28
            ______________
            '68 RS Camaro,
            '99 Monte Carlo LS
