Lumina starter location
  • Ray Hamilton
    • Feb 2007
    • 239
    Don't know anything about the Lumina. Rear wheel Drive or front? And which side is the starter on? Reason: I see "Mr.Gasket" makes a starter heat shield for a Lumina. I'm looking for one that would retro fit on a Fiero 2.8.
    Thanks
    '86 S10 Blazer 4WD, '87 2.8 with 3.1 crank and pistons, A.R.I. "Stage 2 Cam", Iron Heads with stiffer springs, Holley TBI, Manifold bored to fit the TBI Base(4.3 size), Fiero Covers, MSD Coil, DynoMax Muffler and 2.5 Tailpipe, no cat, Auburn Limited Slip, 3.73 final Drive. 700R. '85 Fiero GT 3.4 Hybrid, relieved top intake and exhaust, 57mm TB, Auto. 3.06 final drive.
    a lumi is FWD, and you should find the starter mounted on the left side of the block, using the accessory end as the front.
    • Ray Hamilton
      • Feb 2007
      • 239
      Thanks. That would be the same as the Fiero.
