Coolant drain pet****
  • BLADE
    • Mar 2010
    • 78
    I have a 2004 olds alero 3400 v-6 i was just geting ready to do a coolant flush and was wondering how to get it open i turned it about 1/4 of a turn it moved and stoped didnt want to break it i stopped no fluid came out do i just need to turn it alittle more? And also wondering were the block drain plugs are located any help would be awesome thanks
  • 86FieroSEv6
    • Feb 2010
    • 527
    Once you have the quarter turn, you have to pull it out some then it will turn a little more and pull out a bit farther to open the drain. No block drains that I am aware of, so sorry.
    • Azrael
      Accelerating uphill in OD
      • Apr 2005
      • 763
      There's an accessable drain plug on each side of the block. One's right next to the the crank position sensor and the other's next to the oil-filter mount. I think both require an allen-key wrench.
      Edit: Just looked at a drainplug on my block. It was a 14mm hex headed plug. So it could be either.
      1995 Grand Am SE
      • BLADE
        • Mar 2010
        • 78
        Thanks for the help guys thats what i kinda was looking for allen key in the block i will go cheak those spots and finess the plug out u guys rock
        • BLADE
          • Mar 2010
          • 78
          Just went looked again coudnt find hex head screw but a bolt next to the oil filter about 3 inches to the right of the oil pressure sensor is that one i might have to jack the car up for the other side wanted to do a flush with thermostate out and then drain the block repeate a copple of times anyone have a pic of location of plugs
