I have a 93 Chevy Cavalier Z24 with a 3.1 LH0. I'm in real big trouble here. My cavalier is the daily driver and I'm stressing out on this idle issue, not knowing when my car is gonna eat sh*t and die. When I am in drive and let go of the break it stays about 750 -900 rpm. But when it starts to pick up pace ( no even accelerating, just letting it idle) to a certain speed it will go immidialtely to about 1100 -1200 rpm. which is abnormally high. so that gets the car to about 15mph and stays at that idle speed. and if I go the right speed between 10 and 15mph it will switch from those two idles (750rpm and 1200rpm) at a constant back and forth motion. does anybody know why this could be?
PULSATING IDLE, need help!
Tags: None
Hmmmm...
Is the SES light on?
I'd suspect these things:
1) Dirty throttle body
2) Bad IACV
3) Bad MAP
4) Bad TPS
5) Vacuum leak
-Chris-
03 Black GAGT SedanMODS:
MP Racing CAI / Magnaflow High Flow Catalytic Converter / Flowmaster 80 series w/glasspack resonator
Front STB / MSD Ignition: 8.5mm wires & blaster coils / SOME BIG GODDAMNED MUDFLAPS
And some other stuff to make it look pretty. :D
it depends. somtimes when i start the car and go into drive it will light up. othertimes it takes a while. and on some occasions it goes away. but im leaning toward the tps. i just noticed if you put any tention on the connector plug it will raise the revs.
Switch out the TPS sensor then, they're not expensive to replace.Originally posted by lostboykev View Postit depends. somtimes when i start the car and go into drive it will light up. othertimes it takes a while. and on some occasions it goes away. but im leaning toward the tps. i just noticed if you put any tention on the connector plug it will raise the revs.
-Chris-
