'99 Fuel Rail Reassembly on my 3100
  • Jogasz28
    • Dec 2006
    • 132
    I've got to reassemble the supply and return fittings on the fuel rail my Son took apart instead of the quick-connect fittings. I've got the O-Rings. Is there anything I should know before doing this?
    I figure I'll put a little oil on the O-Rings to prevent damage on assembly.
    Anything else I'm missing?
    BTW, I saw the warning to not grasp the pressure regulator when disassembling.
    I'm sure my Son did. Should I replace the regulator now?
    As always, thanks for all helpful replies.
    jogasz28
    ______________
    '68 RS Camaro,
    Project '69 Camaro in the works
    '95 Monte Carlo Z34 loaded,
    '99 Monte Carlo LS
    You should be fine with a thin film of oil. I've never been told anything about grasping the regulator, so I've no idea on that. One thing you could do to see if the diaphragm is ruptured is to throw a vacuum pump on it before you throw it all back together. If it doesn't hold a vacuum, the diaphragm is bad and it needs replaced. Also, you put this in the DOHC section which gets very little traffic nowadays.
    • Jogasz28
      • Dec 2006
      • 132
      I appreciate the reply.
      My Son and I are pulling a work until we have to stop for whatever reason...so far so good on parts needed I wanted to replace and everythings going (too) smooth.
      Everything is back together except the Throttle Body and upper Engine Mounts.
      So I hope the regulator is all right.
      One thing concerns me:
      I used the Fel-Pro Gasket Kit and used the original 18 Ft/LBs Torque. When I was doing the last go around on the upper intake (no torque sequence in the FM) it didn't feel like the bolts were tightening like I'd expect. I used an Inch/Lb torque wrench. (18 x 12).
      I didn't look for the updated torque specs so I hope I didn't over torque them.
      jogasz28
      ______________
      '68 RS Camaro,
      '99 Monte Carlo LS
      • Jogasz28
        • Dec 2006
        • 132
        Started up the 3.1 last night about 8 o'clock.
        Started on the second crank.
        No leaks.
        No loud noises
        Oils clean.
        Coolants clean
        No leftover parts too!
        We'll run it today for awhile to make sure everything is ok.
        I am one happy SOB
        Thanks to all who helped with replies.
        jogasz28
        ______________
        '68 RS Camaro,
        '99 Monte Carlo LS
