Question about spark plug wires
  • Arisaka
    • Oct 2010
    • 16
    I have some spiral core spark plug wire I need to use.
    Can I use it on the 1999 chevy 3100 engine? Or do I need something with more core resistance?
    Thank You, Jimmy
  • 86FieroSEv6
    • Feb 2010
    • 527
    As long as it is listed as "suppressor" type wire, it's usable. I believe it's in the 1k ohm per foot range.
    • Arisaka
      • Oct 2010
      • 16
      The wire is ACCEL 5000 Series type wires. The wire has suppession for RFI.
      I don't believe the wires have suppression for MFI.
      I think I am going to have to use another type wire.
      Is Bosch spark plug wires good ones to use? Or wires from Taylor cable?
      • 86FieroSEv6
        • Feb 2010
        • 527
        I might be picky, but I usually use MSD or Taylor suppressor type wire. I have seen 250 ohm per foot wire used successfully when routed properly and kept away from the critical sensor circuits. Also, unless you are running a big squeeze box, AC Delco's Delcore wire will perform just fine and it's made by the people who invented our little nightmares.
        • geoffinbc
          Iron Head Enthusiast
          • 5831
          Those Accel wires will work fine. Your not going to find a wires that say "Suppression for MPFI". The suppression comes from the conductor being wrapped around a ferrite core which has a high absorption rate of electromagnetic energy. The tighter the wire is wrapped and the quality of the core will both contribute to the suppression.
          • Arisaka
            • Oct 2010
            • 16
            I used the Accel spark plug wire,so far,so good.
