Oil consumption on a 3100
  • LTZbeast89
    • Apr 2010
    • 22
    Hey everybody!
    My father has a 94 Beretta with that 3100 engine in it. It currently has around 89,000 miles on it. He drives it back and forth from Grand Rapids, MI to Marion, IN (courtesy of GM). Everytime he drives back and fourth he has to put at least a quart and a half of oil in the thing. We take very good care of this car ever since we bought it. It had 69,000 on it when we got it. I've looked countless times underneath and can't see where he would be losing oil. Any ideas what might be causing this?
    Thanks in advance.
    Ryan
  • Azrael
    Accelerating uphill in OD
    • Apr 2005
    • 763
    Could be bad valve guide seals or piston rings.
    1995 Grand Am SE
    • LTZbeast89
      • Apr 2010
      • 22
      That would make sense but it boggles me that it uses oil like that and it doesn't have that many miles on it. are these engines known for something like that? the bad seals?
      • Azrael
        • Apr 2005
        • 763
        These engines are known to be pretty reliable outside of the lower intake gasket problem. A compression test can tell you if it the rings have too much clearance.
        1995 Grand Am SE
        • LTZbeast89
          • Apr 2010
          • 22
          Thats a start. thanks for the help.
          • Azrael
            • Apr 2005
            • 763
            No problem. Did the car ever sit for a really long time without running?
            1995 Grand Am SE
            • Supreme Cutlass 1994
              • Jan 2011
              • 11
              I would have to say oil pump drive seal, I had a similar problem with mine until I did the lower intake gaskets and the oil pump drive seal while everything was out of the way and the o-ring seal was brittle and leaking at 98,000 miles
              • siKKa
                LVS2XLR8
                • Sep 2008
                • 30
                my 98 lumina had the small port 3100. had 150,000 kms when i got it. tons of piston slap, used about 1 litre of oil a week (500ish kms a week) relighable though!
                1994 Cavalier Z24, 5 speed swap, 3500 LX9 (summer ride)
                1998 Lumina LS, (SS) L67 3800 S/C swap (winter ride)
                1999 Honda CBR600 F4, 600cc DOHC I4, cammed.
                • 60dgrzbelow0
                  "Yes... I AM IRONMAN..."
                  • Mar 2009
                  • 1344
                  X2^
                  http://60degreev6.com/forum/showthre...-quick-fix-N-A
                  • siKKa
                    LVS2XLR8
                    • Sep 2008
                    • 30
                    yes but he said oil CONSUMPTION.. not oil leakage
                      • Jan 2011
                      • 11
                      when time and weather are permitting I would pull the upper and lower intake and replace the lower intake gaskets and replace the oil pump drive gear o-ring.
                      my $0.02
                      If they are the original gaskets and o-ring it's only a matter of time until you need to upgrade these.
