1991 Beretta 3.1 - rich smelly and farty
  • themixer
    • Jan 2010
    • 2
    Hello all, I have been on this site for years. Mostly just trolling for information! But here is a problem I have been working on for about 1.5 years now and would like to find a solution.
    The problem: a poor idle (misfires), and VERY rich smelling exhaust, bucking and surging
    what i have done:
    ICM (tested good)
    brand new ACDELCO coilpacks
    ECU (swapped to stock 5 speed)
    new ac delco plugs
    new bosh wires (tested)
    new IAC and replaced with spare
    Cleaned EGR checked the 3 values with a screwdriver they spring back no problem
    Cleaned TB
    new o2
    changed out TPS
    changed out MAP
    tested fuel pressure 43-47 with FPR disconnected
    checked all vacuum lines
    I have a Genesis scan tool and it seems to pick up all the sensors fine. Here is a read out of my car at idle. Even after replacement of all these components. I have had nothing really change on this.
    From what I have learned from beretta.net it seems as if my BLM should be @ around 128 and my MAP sensor should be reading about 20 ihg. When I do an idle relearn, I see the BLM slowy go back down to around 100. As it does this my idle becomes very poor. I am not sure right now if this is the scan tool that I have but my reading for MAP seems to be opposite of what it should be. When I press the gas it wants to jump to 30 when I am off the gas it wants to go towards 0.
    The bucking / surging starts when I am trying to drive a constant speed. Also when taking off from idle there is hesitation, when you goto WOT it will sometimes stumble bad enough to set you forward in the seat.
    I really would love to sort this out I have never quite had problems with a 3.1 like this ever. Any help is appreciated!
  • MY91GT(Z)
    • Sep 2006
    • 387
    the only thing i dont see on you list is injectors you could have a faulty injector that may not be spraying properly i would see bout gettin another set or having your cleaned and flow matched
    • themixer
      • Jan 2010
      • 2
      thanks for the help, I forgot to include I have installed flow matched injectors.
