Ignition timing 1983 2.8 V6?
  • Collomps
    • Jun 2011
    • 5
    Hi to all!
    I am having trouble setting the timing in a 1983 2.8 V6 engine. When i set the timing according to the engine sticker -wich is 10 degrees BTDC- the engine idles ok, but next time i shut it of i cant start it again, the timing seems to be too advanced. I wonder if there is a jumper or something to jump to properly perform the procedure or if there is a cranking signal to the ECM wich delays the timing while cranking.
    HELPPPP!!!
  • geoffinbc
    Iron Head Enthusiast
    • 5831
    On an 83 it will be carb'd with a mechanical/vacuum advance distributor. All you need to do is disconnect the vacuum hose that goes to the distributor and then plug that hose with a large nail. Set the timing with the engine at hot idle. Once its set clamp it back down and reconnect the vacuum hose.
    • Collomps
      • Jun 2011
      • 5
      Hello, thanks for the response.
      The carb is the ECM controlled one.
      My distributor does'nt have centrifugal or vacuum advance, just a HEI ignition system (the one with 7 pins). Should i disconnect a wire or something to perform the adjustment?
      Thanks.
      • geoffinbc
        • 5831
        Ok then yes I believe you pull the plug on the distributor.
        • Collomps
          • Jun 2011
          • 5
          The problem is that i dont see any plug to disconnect. Thanks for the reply.
          • geoffinbc
            • 5831
            The wires that come out of the distributor will go to a plug you can disconnect. Typically the wires are not very long.
