LIM to block seal 3.1 Aluminum head
  • trotterlg
    • Feb 2011
    • 326
    I am going to go out on a limb here and say the LIM to block (valley) seal front and rear is only formed by silicon gasket compound. I’m I correct or do I need to look for more gaskets? Anyone with a preferred brand to use? Larry
  • Azrael
    Accelerating uphill in OD
    • Apr 2005
    • 763
    All the gasket sets I've had came with a small tube of black RTV sealer for those spots. Just about any high-temp RTV will work.
    1995 Grand Am SE
      • 9191
      The 3500s use an actual gasket, but all other engines just use RTV.
      • trotterlg
        • Feb 2011
        • 326
        I thought so, but just checking. Looks like the way to do this is to tighten the 4 bolts that pull the LIM down and then do the 4 corner bolts that pull it towards the head. I saw the torque specs some place. Larry
        • Jesster
          • Apr 2011
          • 41
          RTV varies
          Black is the standard, many people use copper color because of a higher heat capability (not necessary for the LIM application) and then their is gray. Gray is used by many OEMs for valley sealing because it is a little stiffer and has better resistance to antifreeze. Check the labels.
            clean the surfaces really well, i typically use black or copper.. never had a problem with either. 4 centers first then the 4 outers.
            same sequence for a gen 2 or a large port 3x00
