3100 SFI on Buick Century Can't get balancer off
  • Roadbastard
    • Jul 2011
    • 108
    Hello,
    I've been having some trouble trying to remove my balancer. The bolts out and everything but the balancer seems like it's really stuck on the hub. I have the pulley tool, and all it dead was eat the threads that the harmonic balancer screws into. I got a chisel and tapped the balancer being the rear and it moved it enough but not enough to get it off. Any ideas on how to pull this thing? This cars is turning out to be a real PITA.
    The one time I had to pull the pulley on my truck, I didn't realize the washer on the bolt had stayed in the center of the balancer and the balancer wouldn't budge because the puller was pressing on the washer that was pushing on the pulley, not the puller pushing on the crank to remove the balancer. It sucks having to change timing belts out side when the light is vanishing...
    • trotterlg
      • Feb 2011
      • 326
      I made up this tool (from scrap) to remove mine. The center bolt is threaded in, I backed out the bolt holding the pulley about 1/2 inch and then pushed on the bolt head using the center bolt, is slid right off, but it was on hard. Larry
      • rooster5333
        • Jan 2010
        • 29
        mr. roadbastard, start at the beginning and verify all step are done. sometimes it can be a simple "how did i forget that" that usually gets things back on track. make sure all pulley bolts are completely removed. make sure crank bolt, and the huge washer are removed. if there is room. slug it with a hand sledge. no massive blows and never in straight line with the crank. turn the big remover bolt, to put pressure on the balancer. then tap down on the top of the balancer to make it want to give some. remember no very hard blows, you can damage the crank bearings if you do. use a lot of p b blaster or wd 40.
          Hence my post
          • Roadbastard
            • Jul 2011
            • 108
            Thanks, I managed to get it off. My tool was pretty warped that was the problem. I went out and got a new one but the damage was done and it stripped out the balancer bolt hole
              When you say balancer bolt hole, do you mean one of the 3 for the puller in the actual balancer, or the center bolt in the crank?
              *crosses fingers it's the 3 holes in the actual balancer*
                • 9190
                I've actually done this before and I was able to clean out the threads in the crank with a thread cleaner as well as a tap. Be careful when doing it. If its too deep of damage, then you are probably screwed. Mine was only the first couple threads.
                Sent from my DROID2 GLOBAL using Tapatalk
                  Well, if it is the crank, at least a Helicoil > pulling the crank and having a shop do it or replacing the crank. I still hope it isn't the crank.
                  • Roadbastard
                    • Jul 2011
                    • 108
                    It's the crank bolt, I'm just going to helicoil it and call it a day.
