location of tempature sensor for gauge cluster.
  • Jesuscookies
    • Jun 2011
    • 22
    Can someone give me the location of this thing?
    I have a 2 wire sensor that sits directly under the throttle body. I believe this one is for the ECM, correct?
    Where do I find the ever elusive 1 wire sensor that is used for the instrument gauge on the cluster?
    Is it on firewall side of the block? hidden from view or something?
    Thanks for the help.
  • Jesuscookies
    • Jun 2011
    • 22
    Nevermind I found a link that shows a picture, and location of each
    Cutlass Supreme. I need help to replace the coolant temperature sensor. Where is the sensor located and can I get a picture?
    I guess my next question is: can I convert to a 3 wire sensor up front just by rerouting that single wire in back?
      I was going to give it a shot on the 92 when I got around to messing with the car. I imagine it would, but I can't say for sure 100%. In theory, I don't see why it wouldn't as long as the resistance vs coolant temp was the consistent between the 2 single sensors and the 3 wire.
      • Azrael
        Accelerating uphill in OD
        • Apr 2005
        • 763
        If it's a 94-95 car you can probably use the acdelco sensor 213-815. It uses a similar connector to the throttle position sensor and the middle pin is the single wire.
        1995 Grand Am SE
        • Jesuscookies
          • Jun 2011
          • 22
          yes, it's a 1994 oldsmobile. I'm not too worried about parts at this point. My question is really about the amount of work involved. Is it just a matter of taking the single wire from the gauge sensor and running it to a 3 prong plug, then hooking it to a the 3 wire sensor? Do I have to swap the ECM, or is there any other involved process to contend with?
          I think it would make more sense for the gauge and ECM to have the same information.
          • CNCguy
            Bisong eater :P
            • 1017
            No need to change ECMs. If you don't want to cut and splice, you can use a three pin wiring adapter like this.
            MinusOne - 3100 - 4T60E
            '79 MGB - LZ9 - T5
            http://www.tcemotorsports.com
            • Jesuscookies
              • Jun 2011
              • 22
              http://britishcarconversions.com/com...category_id=29
              How freaking cool is that!
              If the adapter and wires are long enough this would just be plug and play right?
              • CNCguy
                Bisong eater :P
                • 1017
                IIRC, they are around 10~12" long but we build these in-house and can put one together with the lengths you need. Just let us know how long each lead needs to be.
                '79 MGB - LZ9 - T5
                • Jesuscookies
                  • Jun 2011
                  • 22
                  Cool I will contact you through PM or directly on your site. Thanks for the help!
                  • Jesuscookies
                    • Jun 2011
                    • 22
                    Thanks CNC guy! Got the new sensor, and adapter hooked up. Didn't have to remove the throttle body either. Offically changed over to a 3 wire temp sensor for the gauge and ECM together.
                    I was thinking I can use the old gauge sensor spot to put a lower temperature sensor in, if need be, to trick the ECM into turing on the fan eariler? Does anybody know what sensor, from what car, I can use to get the fans to turn on at 190, instead of the normal 230?
                    • Azrael
                      • Apr 2005
                      • 763
                      If anyone knows the resistance of the sensor at those 2 temps, it should be possible to find the value of a resistor you could wire in parallel to trick the PCM into doing just that.
                      1995 Grand Am SE
